Author Topic: V7 rear caliper  (Read 2305 times)
Offline mechanicsavant
V7 rear caliper
« on: March 21, 2023, 07:33:51 PM »
This may have been discussed before & i missed it . But the underslung rear brake caliper does seem to get an inordinate amount of road swarf accumulate in it . Why no drain holes ? Has anybody drilled any holes ? Sometimes I’m removing the caliper after a weekend rally & am amazed @ the accumulated debris after under 1kMi. Weekend of mixed riding conditions .
Online Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
Re: V7 rear caliper
« Reply #1 on: March 21, 2023, 07:53:20 PM »
Better spray it all down with lots of WD40 ;)
Re: V7 rear caliper
« Reply #2 on: March 21, 2023, 08:16:14 PM »
Grease the disc, that will draw the dust and debris away from the caliper… :grin:
Re: V7 rear caliper
« Reply #3 on: March 22, 2023, 12:18:18 PM »
Both of those solutions also have the side benefit of extended brake pad life . The trade-off being reduced stopping ability . I just got done drilling & deburring 2 3/16 holes in the recessed areas on each side of the web that holds the anti-rattle spring in place . At least some of the stuff that builds up there may have an escape route . Also put speed bleeders in @ both ends . Bleeder @ the bottom , really !
Online Dirk_S
Re: V7 rear caliper
« Reply #4 on: March 22, 2023, 02:31:26 PM »
You should still hose all of that down with WD40 to make sure the debris doesn’t stick around.
Re: V7 rear caliper
« Reply #5 on: March 23, 2023, 06:58:20 AM »
Sorry Dirk , no slippery stuff near my pads or rotors . Next time it’s apart I’ll very probably put a good coating of high temp ceramic paint on the caliper bracket & caliper . All sliders & areas the pads contact the caliper usually get a very slight film of brake support lubricant .
It’s just a nasty environment for a caliper , were it located on the top or rear of the disc I’ bet it would stay cleaner longer . Thanks for your input .
Re: V7 rear caliper
« Reply #6 on: March 23, 2023, 07:01:04 AM »
All joking aside, maybe it's a difference in ambient conditions but I don't see a problem on the rear caliper of either of our bikes.
Granted they do get some schmutz on em, but not nearly enough for me to be concerned personally.
And I guess, I mean, I don't always even use the rear on them. I do for certain circumstances or HARD stops, but much of the time it's front only anyway.
Re: V7 rear caliper
« Reply #7 on: March 23, 2023, 01:00:56 PM »
Yeah Kev I primarily use the front brake w/a slight assist from the rear when on asphalt . Many times there seems to be an interesting well groomed Dirt or hardpack road to explore . Also a few amigos live on such tracks . So I’m tempted to say “wonder where this one comes out ?” Usually it’s pretty cool , when it gets knarlly I”lol do a “crazy Ivan “ & find an alternate route . A couple of “Ice breaker”rides this spring Allowed A fair amount of road salt kinda stuff to build up in the recesses of the rear caliper . Even though I’d hose the bike off before putting it away .As i mentioned earlier I’ve added a pair of drains to the rear caliper . The next couple of weeks should be a decent Test to see what happens . There’s still quite a bit of sand & whatever out there . But when it’s sunny & above 40 ish deg. I’m trying to chew through the leash & go !
Re: V7 rear caliper
« Reply #8 on: March 23, 2023, 01:21:37 PM »
 :thumb: :thumb: :thumb:
