Author Topic: Red Elbow fuel connector under tank  (Read 3587 times)
Offline mr_pacman
« on: April 15, 2023, 08:07:28 PM »
No, I haven't broken the red plastic elbow under the fuel tank but it's just a matter of time.
Has anyone tried this product by chance to replace it?
https://ziptyracing.com/products/fuel-pump-elbow-oem-8000ah2930-gte-fi-husky
I found a link to it on another website that suggested it would work as a direct replacement.
I've read the same part is sold by Ford UK for the Fiesta and Escort but, they are very difficult to find and I would rather install something that is stronger if possible.
thanks
james
« Last Edit: April 15, 2023, 08:08:16 PM by mr_pacman »
Offline Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
Re: Red Elbow fuel connector under tank
« Reply #1 on: April 15, 2023, 08:20:54 PM »
Not sure if this is the exact same thing, but AF1 sells an elbow port as well, that they list as a fitment— https://www.af1racing.com/ZT-GTE-FI-HUSKY-Zip-Ty-Racing-Male-Aluminum-Fuel-Tank-Fitting
Also—thanks for the new paranoia that I’ll now have.
Offline mr_pacman
« Reply #2 on: April 15, 2023, 09:26:12 PM »
That does appear to be the same product and they suggest it fits the full range of V7 bikes as well as many others.
I'll see if I can find the red plastic Ford part first and , if not, I'll buy one of these. Thing is, I don't think the "quick connect" part on the fuel line is going to connect to this metal elbow so I'll have to figure out how to connect it securely.
Offline Bulldog9
« Reply #3 on: April 15, 2023, 09:35:01 PM »
Unplug the fuel pump electrical connector, then cycle the starter. Will depressurize the fuel line and make disconnecting much easier.
MGNOC#23231
Offline Pescatore
« Reply #4 on: April 16, 2023, 09:13:28 AM »
Seems like a good solution.  I would snatch the last one they have in stock.
If anyone has a spare plastic version we could compare dimensions before taking apart the tank.
I wish they sold just the elbow and lowered the price.
2008 Norge red
1991 V65GT
1980 CM400T
MGNOC Member
Offline pauldaytona
    • Paul's fast Guzzi Page
« Reply #5 on: April 16, 2023, 03:50:12 PM »
The original plastic is also available from your dealer.
AP8104192
But the aluminium one looks good, and looks to survive everything
Paul
Daytona 1225, Stelvio 1151
Offline Brand X
« Reply #6 on: April 17, 2023, 09:57:59 AM »
The aluminum is different in that you need to drill out the side of the pump housing to allow it to stay in place. It will work for some ,and not for others..
I still have one in my parts, and just bought a replacement from AF1
Offline mr_pacman
« Reply #7 on: April 17, 2023, 10:01:22 AM »
You bought a plastic replacement or an aluminum replacement?  If it was the plastic, does AF1 have those as I can't find them on the website.
Offline Brand X
« Reply #8 on: April 17, 2023, 10:16:38 AM »
I bought both. ended up using the factory style from AF1  It took forever to get the aluminum shipped, and really was not the best one to use. (IMO)
V-7 would not be a good option for Aluminum.. Breva it could work, but just plug, and play for plastic..
https://www.af1racing.com/MG410-Fuel-Tank-Fitting--Plastic
« Last Edit: April 17, 2023, 10:22:59 AM by Brand X »
Offline mr_pacman
« Reply #9 on: April 18, 2023, 08:29:47 PM »
Update. Found a UK seller on Ebay that was open to using the Global Shipping Program. Prices were reasonable on both the parts and the shipping. Bought an extra one as a back up.
Thanks for all of the help. The aluminium one looked interesting but after reading a few posts, felt the stock plastic plug and play version might be better for me.
Offline Bulldog9
« Reply #10 on: April 19, 2023, 07:37:42 AM »
My concern with the aluminum elbow is the need to make permanent modifications, but also on the impact it may/may not have on the rest of the connection. I'd use plastic wherever possible for long term servicibility of the fitting as it is all plastic as well. BLUF: Metal to Metal-Plastic to plastic.
I think have a couple of these in my parts stash. Haven't needed one yet thankfuly.
MGNOC#23231
Offline Brand X
« Reply #11 on: April 19, 2023, 11:59:38 PM »
England has access to the red Ford connectors, and are the exact same as factory Aprilia/Guzzi parts.
Offline gscott
« Reply #12 on: April 20, 2023, 08:10:32 AM »
Fuel connector disconnect fitting
Ford part number:  Red is 1330328. Same in white is 1072003.
2007 Norge - silver
2000 Quota - black
2000 V11 Sport - green
2000 V11 Bassa - pearl white (the one that got away)
Offline mr_pacman
« Reply #13 on: April 20, 2023, 08:50:30 AM »
Anyone have a source for the quick disconnect adaptor that fits over these red/white plastic elbows?  Do they also need to be replaced often or is it more just the elbow connector that causes the issue?
Offline Brand X
« Last Edit: April 20, 2023, 11:54:42 AM by Brand X »
