Author Topic: California Jackal vs Bellagio?  (Read 4431 times)
Offline La Dolce Guzzi
« on: April 18, 2023, 05:31:31 AM »
Hi Guzzi Gang,
I've got a V7 II and looking to upgrade to one of the older Guzzi cruisers. It just so happens that for sale near me is a 2000 Cali Jackal and 2010 Bellagio, both fairly stock, both with about 20K miles.
What is the Guzzi hive mind's view on their:
1) build quality
2) parts availability
3) future collectability
4) any known issues or faults I should be aware of?
Thanks in advance...
« Last Edit: April 18, 2023, 05:33:12 AM by La Dolce Guzzi »
Online Frenchfrog
Re: California Jackal vs Bellagio?
« Reply #1 on: April 18, 2023, 06:15:43 AM »
The Bellagio....much more zip and the engine isn't really a "cruiser ". Take both for a really long spin if possible.
« Reply #2 on: April 18, 2023, 06:19:03 AM »
I loved my Jackal (but I also hated it, too many niggling issues).
If conditions are comparable Bellagio all the way. But to be fair I've never even seen a Bellagio IRL cause they were never sold here.
« Reply #3 on: April 18, 2023, 08:03:10 AM »
Keep in mind that both bikes IMO will need all the rubber bits changed.  Brake lines, too and possibly master cylinder rebuilds and such.  Those items simply age out.
That said, several years ago I bought a 2001 Jackal and loved it.  Had to sell due to relocation and much smaller space.  Less that a year later, I'm buying it back as it just has to be my bike.  Be careful............ ..
« Last Edit: August 02, 2023, 01:40:30 AM by kingoffleece »
« Reply #4 on: April 18, 2023, 08:03:57 AM »
Oh, I also had to renew the entire charging system.  Parts were a bit dear.
« Reply #5 on: April 18, 2023, 08:17:49 AM »
Bellagios never came to the US but I spent about 6mos in Spain back in the 2010's and I knew 3 guys with them. They all loved the Bellagio and sang the motor's praises. It's an oversquare short stroker- sounds like it loves to have its neck wrung and excels on the back roads. Unfortunately the Bellagio isn't much lighter than other CARC models- the 850 in it shares the same engine block and overall layout as the 1100/1200 CARC models. The riding/foot position closely mimics the Norge/Sport1200/Breva but the bars are lower than Norge/Breva. The Jackal has a more relaxed cruiser riding position and would be generally more suited to that riding style.
The Jackal has more power, but the CARC bikes are some of the very most reliable Guzzi made and the Bellagio is just a newer bike all around with better suspension, brakes, etc.... Keep the revs up and change the clutch fluid every time you do the trans/final drive fluid... It should give you many happy miles. I dont agree that you would need to replace every piece of rubber on the Bellagio, depending on how they were stored and how regularly they were ridden.  I have an '07 Breva 1100 that got almost no miles the first 8 years of its life but was stored inside a garage. I have put about 23k miles on it over the last 9 years and I havent had to replace any rubber bits due to degradation. It has eaten a couple sets of fork seals, but I am a hefty guy, ride pretty aggressively, and do a lot of 2-up riding on that particular bike.
« Last Edit: April 18, 2023, 08:28:44 AM by Mayor_of_BBQ »
« Reply #6 on: April 18, 2023, 08:22:16 AM »
I documented my Jackal here over the ~8-9 years ~35k miles I had it.
Replaced all hoses/oil lines etc, some gaskets, regulator, starter, tail-light (like everyone else).
This along with shocks and fork seals that leaked in the first year, bodywork and wheels that rusted, and I know I'm forgetting stuff.
The rest of the chassis, the brakes, and most importantly the motor/drive train were stout, probably bulletproof. Everything else around them was going POOF.
« Reply #7 on: April 18, 2023, 11:15:01 AM »
We can agree to disagree about the rubber.  It was mentioned as I found several parts degraded from age and use when I got mine, thru no fault of the guy I purchased it from-and it's not the first time.
No harm-no foul for not doing anything-it's the buyers choice.  I prefer to ride knowing that parts which are scheduled for a service life and/or duty cycle have been addressed.
Doesn't mean that's necessary for anyone else-but it's right for me.  10 years of professional SCUBA instruction in almost every environment tends to reinforce the need for routine and preventative maintenance.  Lessons learned have stayed with me.  YMMV, as it should.
Online Frenchfrog
« Reply #8 on: April 18, 2023, 11:28:06 AM »
Without checking I can't be sure but as I remember it the power output between the two bikes is similar....it's just all about how it gets there.
The Bellagio loves to be thrashed ( strange that they dressed it up as a cruiser really ) and the Jackal will be the usual longlegged  Guzzi style and a bit lazy in comparison.
Offline Moparnut72
« Reply #9 on: April 18, 2023, 12:50:46 PM »
The aging of rubber is dependent on various factors. Sunlight is a major problem. Ozone is a big one, prevalent in cities and proximity to electric motors.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
« Reply #10 on: April 18, 2023, 01:44:15 PM »
Not trying to start static.. just diversity of opinion. But isn't a jackal also a bit older than a Bellagio?? YMMV
« Reply #11 on: April 18, 2023, 05:51:40 PM »
I just woke up to see all the replies and advice -- many thanks!
So my take away is the engine and drive train are stout but the ancillaries need some careful evaluation. And the Bellagio is the more sporty of the two while the Jackal is your classic Guzzi cruiser that's tried and tested.
I've read that the Bellagio is a bit of an odd duck in that it has the CARC system bolted onto the Tonti frame, but it somehow seems to work.
Would the Bellagio more of a collector's bike in the future over the Jackal?
« Reply #12 on: April 18, 2023, 06:54:38 PM »
I don't think either of them are destined for "collectors" status.
That said, I would take a Bellagio in a heartbeat and would probably pass on a Jackal.
If I really was interested in another Call it would be a Cal'Vin or Black Eagle.
But I'm very happy with my smallblocks and feel no need to go backwards to a Cali again.
Now let's talk about the V9 Bobber Sport!
« Reply #13 on: April 18, 2023, 09:07:27 PM »
Said the Borg: Resistance is futile
« Reply #14 on: April 19, 2023, 06:28:45 AM »
Bellagio love incoming to your PM box....
Offline Murray
« Reply #15 on: April 19, 2023, 08:44:55 AM »
It's a Guzzi and a cruiser, none of them are likely to ever become particularly collectible.
Offline bad Chad
« Reply #16 on: April 20, 2023, 09:31:45 AM »
Agree with Murray, I would go with the Bellagio of the two, but each has its strong suits.
1988 YX600 Radian
Online Bulldog9
« Reply #17 on: April 20, 2023, 06:38:23 PM »
I'd love to add a Bellagio to the mix.
On the rubber bits part, my 07 Griso had SS brake and clutch fluid lines, and has not had a single piece of rubber or such replaced except the alternator belt. Love the CARC bikes.
MGNOC#23231
« Reply #18 on: April 25, 2023, 01:08:11 AM »
Hey Kev, I sent you an update re Pete but not sure if it went through. Had a great chat with him about all things Bellagio in Aus! What a Legend.
« Reply #19 on: April 25, 2023, 06:48:10 AM »
« Reply #20 on: August 02, 2023, 01:36:52 AM »
All's well that ends well. I ended up getting that Bellagio and I love it...
Many thanks for all pre-purchase guidance and input
« Last Edit: August 02, 2023, 01:38:51 AM by La Dolce Guzzi »
« Reply #21 on: August 02, 2023, 01:42:43 AM »
That is a real sweetheart.
Offline pauldaytona
    • Paul's fast Guzzi Page
« Reply #22 on: August 02, 2023, 05:10:47 AM »
I know someone who had a beautiful Cali Vintage and traded in on a Bellagio because the vintage was him to heavy, and he loves the Bellagio now.
Paul
Daytona 1225, Stelvio 1151
« Reply #23 on: August 06, 2023, 03:49:32 AM »
Thanks @pauldaytona and @kingoffleece! Will post more pics and experiences once I get to the other end of our Southern Hemisphere winter.
Make the most of your summer riding days!
Offline dguzzi
« Reply #24 on: August 06, 2023, 06:52:35 PM »
  Looks like a Hydro EV could fit right in, ----hmmmm
'03 EVT
'87 Cagiva
'72 Commando
'71 Commando
'13 F150
'16 Mustang
