Author Topic: Comparing ECU maps 2019/2021 V7 lll Stone 750  (Read 3050 times)
Offline Beavis
« on: April 25, 2023, 03:51:12 AM »
Hi to all , I have two V7 lll Stone 750 ( 2019 night pack and 2021 basic) and since I bought the 2021 I have noticed that don't perform same ( worst) also makes so pinging or wrist pin sound like with only 3800km. Already adjust the valves and performs a little better but not , the same as the 2019. Also don't pass 170 km/h , and I think it can do a little more.
d picture
So finally received my ECU cable and read both ECU - The 2019 have a map dated 2019-6-19 and the 2021 a map dated 2017-10-12. So the newer have a older map inside.
So I'm going to put the 2019 map into the 2021 and test.
Can someone share a newer map .bin file or this is the latest for my bikes?
Or any other suggestions?
Thx
Offline chrisfer
Re: Comparing ECU maps 2019/2021 V7 lll Stone 750
« Reply #1 on: April 25, 2023, 05:26:51 AM »
Same software (464AVFAL) => same map.
Pinging is current on this motor and may be due to a very slight difference in compression (and even exhaust valve, timing, and lambda sensors...).
Try a richer map for V7 III 750 : http://forum.guzzi-passion.com/viewtopic.php?t=24215
« Last Edit: April 25, 2023, 05:27:23 AM by chrisfer »
2022 V7 850 Stone - 2019 V7 III Carbon - 2004 V11 RossoCorsa - 2002 V11 Le Mans - 1995 750 Nevada
Offline HarveyMushman
    • Photo Galleries
« Reply #2 on: April 25, 2023, 05:39:39 AM »
Try Beetle's map: www.griso.org
Tim
Offline Beavis
« Reply #3 on: April 25, 2023, 06:45:11 AM »
So the maps are the same , even with different dates? So how to explain same engines, same maps , and different performance? Should I consider that my newest with only 3800km is in the break in period?
« Last Edit: April 25, 2023, 07:47:38 AM by Beavis »
Offline Beavis
« Reply #4 on: April 25, 2023, 06:46:56 AM »
Will have that in consideration. Thx 😊
Offline Vagrant
« Reply #5 on: April 25, 2023, 08:24:08 AM »
I believe the 19 is a E4 bike but the 21 is an E5. Totally different specs. I think upmap is the only choice on the 21. Also isn't the 21 an 850?
Offline Beavis
« Reply #6 on: April 25, 2023, 08:49:03 AM »
Nop. Both 750. Mine was the last of his kind.
Offline Beavis
« Reply #7 on: April 25, 2023, 09:28:18 AM »
Here we go : V7 lll Chrisfer tune 66 custom map.
Offline Beavis
« Reply #8 on: April 25, 2023, 01:48:27 PM »
which version do you advise? The latest V7III_Chrisfer_Tune _66 or V7III_Chrisfer_Tune _66_igni_origin?
Offline chrisfer
« Reply #9 on: April 25, 2023, 02:07:08 PM »
Offline Beavis
« Reply #10 on: April 25, 2023, 02:10:40 PM »
Already there then. Totally forgot to reset the auto learning values after upload the new map.
« Last Edit: April 25, 2023, 02:17:07 PM by Beavis »
Offline pauldaytona
    • Paul's fast Guzzi Page
« Reply #11 on: April 28, 2023, 03:56:34 PM »
The date you see in the map, is the date the map was put on the ecu.
Paul
Daytona 1225, Stelvio 1151
Offline Beavis
« Reply #12 on: April 28, 2023, 06:31:44 PM »
indeed. But strange to have a 2017 map in a 2021 bike. :)
« Reply #13 on: April 28, 2023, 07:08:52 PM »
Not if nothing has changed on the engine. Motor wise same stuff.
