Author Topic: Crank Position Sensor  (Read 2934 times)
Offline billyb
« on: April 26, 2023, 12:29:36 PM »
My 1996 Cali 1100i has developed a problem. It will run sweet for about 20 minutes, then start to cough and violently backfire before stopping completely. If I let it sit for about 20 minutes, it will start again and maybe run for another few miles before repeating the backfiring and then quitting. Coils and plugs and fuel supply all seem to be ok.
Could this be a faulty Crank Position sensor? Do they effectively heat up in operation which may cause the fault and the engine to quit, and then cool down again allowing me to restart the engine?
Any help appreciated.
Offline pressureangle
Re: Crank Position Sensor
« Reply #1 on: April 26, 2023, 12:54:44 PM »
Exactly so, yes.
Offline jrt
« Reply #2 on: April 26, 2023, 01:00:08 PM »
When the CPS died on my Cali, it also died when hot- but it didn't sputter, it just died.  I started a thread on the topic sometime last summer.  Kiwi Roy suggested connecting an LED from the fuse to the fuel pump to ground and from the fuse to the ignition (coils) to ground.  It gives you an indication of what's happening- the fuel pump should cycle ~3 sec when you turn the key on, then turn off, then turn on again when the bike is running.  The coils should energize.  Keeping the coils energized (when motor is spinning) is dependent on getting a signal from the CPS.
At least- that's what I have from memory.  Do a search for thread started by me, and there is a diagram for wiring and a lot of discussion.   I ended up replacing mine and had to source a CPS from Latvia, of all places.
There are different versions of the CPS- some when on the flywheel, some on the timing chest.  Some were two-wire, later ones were three wire.  If you have the one on the timing chest, I can loan you the tool I made to measure the depth from the mount to the timing gears.
« Last Edit: April 26, 2023, 01:01:11 PM by jrt »
L-720
1973 Eldorado
2003 Yardbird (1100 hydro)
2020 R1250RS
Offline billyb
« Reply #3 on: April 26, 2023, 01:06:45 PM »
Thank you
Online pehayes
« Reply #4 on: April 26, 2023, 01:08:30 PM »
Sounds like fuel vacuum starvation.  When it stops, can you remove the fuel cap?  Or does vacuum hold it tight in place?  Vacuum develops as the fuel level drops.  It is not safe, but maybe consider a ride with the fuel cap loose to prevent vacuum.
Have  you done anything about fuel filter?  There are two and people commonly neglect the more important one.
There is a huge filter under the center tunnel of the tank.  Guzzi recommends a short interval of perhaps 12K miles.  I have run them many more miles at 40K.
However, there is also a small, pencil-sized filter inside the tank on the input line of the petcock.  Debris gathers inside the tank and gets stuck onto that filter while running.  When  you stop and the fuel flow stops, t hat debris gradually falls off the pencil filter until you start running again.  Consider removing the tank, removing the petcock, and doing a good interior flush of the tank.
Offline Rolf Halvorsen
« Reply #5 on: April 26, 2023, 01:10:57 PM »
I believe the article number for this sensor is 29721660 and this is the 2 pin version.
(01721600 is the 3 pin version for the V11 series.)
Rolf
« Reply #6 on: April 26, 2023, 01:50:44 PM »
Like Pat says check both filters.   :thumb:  Especially for your year of Cal.  The sensor can be checked easily.  You start with the basic fuel delivery first.
Offline Tkelly
« Reply #7 on: April 26, 2023, 02:15:53 PM »
I had those fail on 2 different bikes,once they failed you could crank the bike forever and it wouldn’t fire up.
Offline Speedfrog
  • Vieux motard que jamais!
« Reply #8 on: April 26, 2023, 03:17:53 PM »
Is there an easy way to check if the CPS is faulty?
'04 V11 Café Sport - '14 Griso 8V SE
Offline nc43bsa
« Reply #9 on: April 26, 2023, 03:49:26 PM »
Check for continuity with an ohmmeter.
1990 MilleGT
« Reply #10 on: April 26, 2023, 04:39:31 PM »
Yes and no. This unit can fail...as a Brit. That is it can work when cold and fail when hot. When I bought my '97 Sport-i the sensor was bad; the first ride I got 3 miles, ten minutes later struggled home. The next day, started perfectly and I let it warm up before going out- made it about 1 mile. Back again the following day after a bunch of ignorant new-owner checks, same good start but didn't make the end of the block and pushed it back. I think that's when I found this forum. I tested the CPS in situ cold and it checked fine. Once more, let it get warm and when the block reached about 150* it started to sputter. I pulled the CPS and bench tested it multiple times with a heat gun and it consistently failed about 160*. New sensor, no problem. So yes you can ohm it in place but you have to ohm it in place *during failure* and hot to be certain it's failing.
Offline JoeB
« Reply #11 on: April 27, 2023, 06:22:17 AM »
Went through this on my 98EV a few years back. Quite a few posts on it over the years.
Found this one off the bat: https://wildguzzi.com/forum/index.php?topic=85714.0
In my case measuring resistance of the sensors led me to an ez fix.
« Reply #12 on: April 27, 2023, 07:49:59 AM »
You say it backfires. To me that sounds like the injectors are still hosing in fuel. Which means the crank sensor is still working, just that the spark is poor.
Have you tried relays?
But that has two sensors and it is not clear to me what happens when one sensor goes whacky, so it could be that.
Offline Vagrant
« Reply #13 on: April 27, 2023, 09:10:07 AM »
Have you ever replaced the TPS?
