Author Topic: Disappointing dyno run and poorly tuned carbs- PHF36 on CX-100  (Read 6068 times)
Hello all,
I have an extensively modified CX-100 that I bought from a former member on this board. Tho I love a great many things about the bike, I have come to learn that a lot of the work done on the bike was shoddily completed and generally 'off'
I had the chance to briefly put it on a dyno at a bike show this week, and tho it was a quick couple runs up to WOT, It was immediately clear that I have EXTREMELY lean running condition on the bike, and the HP is probably nearly 30% under what I should be getting (@40hp)
couple quick things about the bike before I get to the question:
1. 1979 CX100
2. PHF 36b carbs
3. Lafranconi pipes
4. K&N pod filters
5. bike is said to have a hot cam (no I don't know which one)
6. bike is said to have had 'head work' (assumed polished but unsure of extent) I believe the valves are stock
7. The bike starts flawlessly (on choke) and idles perfectly (maybe a little cold blooded for a min or two), it's pulls smoothly thru the range, never coughs/surges/sputters or anything like that.
The guy running the dyno is a well regarded local vintage wrench/tuner/restorer/machinist. His specialty mostly Brit bikes, but he is known quality with BMW, Guzzi, and Ducati as well.
His comment was "way, way too lean! Go up 4 sizes at least on the main jets. She's got a LOT more to give"
___________________ ___________________ ___________________ ___________________ ___________________ ___
Now, I have always been confounded and a little disappointed in the performance of this bike, mostly because it was marketed as a hot rod.
Honestly, I've never ridden any other Tonti 850/1000/1100, and I have nothing to base it off of. My other Guzzi were a very strong running v65, an good running rebuilt Ambo, and my Breva 1100.
This CX100 is faster than the Ambo by a fair bit (ambo weighs a ton tho), but it's barely faster than the v65, and my Breva would absolutely blow its doors off.
Ever since I got it, I ended every ride thinking "huh, I really thought this thing would be faster" but it's not a dog or anything...  I keep telling myself "the small block was much lighter, the Breva is much more powerful, and the CX100 was never a race-derived bike, it has a touring bike 949cc motor and it's 45 years old- so whatta you expect??"
But yet with the stated mods and this supposedly 'built' motor, it just doesn't have the sauce I thought it would.
SO after that sprawling preamble (we are here for campfire discussion, right?)
* I pulled the main jets- they were 140 -I ordered a set of 145 mains and hope to get them tomorrow
* I checked the needle (no idea which needle it is) and it was clipped at the lowest groove (richest possible setting)
* I am not going to mess with the idle jets at this time, as I said it starts, idles, and runs great at low engine speed
___________________ ___________________ ___________________ ___________________ ___________________ _____
At long last, THE QUESTION:
Assuming the 145 mains wake this thing up, what should I do about the needles?
1. run the 145's and leave the needle where it is?
2. run the 145's and move the needle to the middle?
3. run the 145's and drop the needles all the way
4. replace the needles with something else (and set them on what clip?)(how/where would I measure the needle to determine what I have currently?)
___________________ ___________________ ___________________ ___________________ ___________________ ______
If you read all this, thank you. Please let me know what your thoughts are.  This guy drags the dyno trailer to a handful of events over the summer, so I hope to make some changes, check it with the butt dyno, and then get back somewhere I can put it on the dyno again.
Offline Gliderjohn
Re: Disappointing dyno run and poorly tuned carbs- PHF36 on CX-100
« Reply #1 on: May 04, 2023, 01:17:41 PM »
A few thoughts...
First, is everything tight and leak proof (manifolds, etc.)?
Are petcock screens or or any other fuel filter flowing a 100%. Air filters clean?
Change needle for more flow.
My T-3 has the 949cc kit, 36mm, cam for the old V-7 Sport and heads ported and cleaned up. Valves are stock. K&Ns and cheap Emego mufflers. My mains are either 130 or 135s. Here is the dyno chart. The low RPM dip was intentional.
« Last Edit: May 04, 2023, 01:18:15 PM by Gliderjohn »
East Mountains, NM
guido guzzi
« Reply #2 on: May 04, 2023, 01:28:29 PM »
Needle chart on This Old Tractor https://www.thisoldtractor.com/dellorto_slide_needle_specifications_for__phbe-phf-phm-phsb-vhsb_carburetors_-k_slides-.html
I believe Guzziology mentions that double digit needles were made as concessions to emissions regs.
Numbers are stamped on the side of the needles.
« Last Edit: May 04, 2023, 03:43:49 PM by guido guzzi »
Offline pressureangle
« Reply #3 on: May 04, 2023, 02:31:42 PM »
As above, make certain everything is in order with the fuel delivery and air leaks. Having the valves adjusted is also important.
The most important thing to remember about jetting, is change only one thing at a time. You can't know how much a larger main jet will enrich the needles if you move the needles at the same time as you increase the main jets. The tedious answer to how to get where you're going is to increase the main jets one size at a time and chop the plugs properly (ignition kill at WOT high rpm) until you get a little color on them. Whether the motor wants them light tan or medium brown is a question for the dynomometer but typically hemi head engines like to be on the darker side. After you get the mains right, then you can go back and ride around casually to find the best home for the needles. It is possible that along the way as you increase mains that you'll get a rich stumble in the needles in which case you sort of have to drop them a slot or two.
Don't be disappointed in the performance until you prove that proper jetting doesn't bring hoped for results.
guido guzzi
« Reply #4 on: May 04, 2023, 03:50:22 PM »
Ed Milich devised this recipe for a Sport 1100 which probably breathes better than your bike - how much depends on the heads and cam I guess...
Works great on my stock Sport - 40mm PHMs
K4 needle clip in lowest groove
128 Main
68 Idle
50/3 slide
265 Atomizers
Guessing your atomizer (needle jet) is smaller because 140 mains were too small.
Atomizer and needle establish the range in which everything else works...
« Last Edit: May 04, 2023, 04:12:08 PM by guido guzzi »
Offline reidy
« Reply #5 on: May 04, 2023, 04:26:46 PM »
One trick that I was told, and appears to work especially for main jets which have the most effect at wide open throttle is to do a run on the road or dyno and see how it performs. Then pull the choke a small amount to open the enrichment circuit a little. If it responds better the mains are to small. It should respond worse if the mains are the correct size.
Offline Tony F
« Reply #6 on: May 04, 2023, 06:43:10 PM »
A few thoughts...
My SP1000 (same motor) ran this spec for a time and my recollection of the mainjet size is as GliderJohn says. Certainly not 140 or above.
How many miles has the engine done and what is the mechanical condition? Valve guides? Valve sealing? Ring condition? A compression or leakdown test might be a good place to start. Was the squish clearance set at a reasonable level?
Tony
'79 SP1000
KTM Duke 890R
MV Agusta F4 (x2)
Online Tkelly
« Reply #7 on: May 04, 2023, 06:55:26 PM »
ASI recall that is a fine looking bike,it is faster than a couple of you other bikes that go 100,it runs great and is 44 years old.The old adage if it’s not broke don’t fix it may apply here.No guarantees that it wont run worse if you mess with it.I bought a78 T3 that supposedly goes over 100 but I don’t intend to find out because it runs just fine up to about 75 andI don’t ride it on freeways.
Offline John Croucher
« Reply #8 on: May 04, 2023, 07:30:22 PM »
Take the main jets out and ride it.  See if the needle and needle jet are correct.
Offline Turin
« Reply #9 on: May 04, 2023, 07:31:16 PM »
What do the plugs look like?  have you tried messing with the timing?
1985 Sidlow Guzzi
Offline Gusable
« Reply #10 on: May 04, 2023, 07:53:15 PM »
My 36’s have a 145 main and run great. I wouldn’t hesitate to throw those in. There’s thinner/richer needles you can get, jets are cheap. I bought quite a few carb parts before I was happy with mine. Now I have a little carb tuning box with new jets and needles I can play with.  The WOT run though is main jet tuning so start there
1994 California 1100
Online moto
  • Fear the deer!
« Reply #11 on: May 04, 2023, 08:44:59 PM »
My advice is to not take advice from online forums until you know enough not to need the advice in the first place. That is, you will find contradictory advice, and you need to know how to evaluate it.
My best recommendation is to study the Dellorto tuning manual. They built your carb, and they give instructions on how to tune it.
Once you have absorbed that manual, you will be able to appreciate the rare beauty of elliptical advice such as John Croucher’s. Until then you will be lost, grasshopper.
You can do it.
Moto
« Last Edit: May 04, 2023, 08:59:27 PM by moto »
850 T-3
Griso 1100 corretto
Online PeteS
« Reply #12 on: May 04, 2023, 09:36:12 PM »
145 mains actually sounds about right. My 850 LM runs 143 mains. Determined at the dragstrip giving best ET and top end.
Never had it on a dyno but would estimate close to 60 RWHP. Pulls over 8k RPM in fifth with more on tap.
Stock Cam, Raceco heads, K&N pods, Renn Sport exhaust.
« Last Edit: May 04, 2023, 09:38:29 PM by PeteS »
« Reply #13 on: May 05, 2023, 07:18:07 AM »
A few thoughts...
Yes thanks John
I have just gone thru the exhaust, all is tight and right. When I got it the crossover was loosely installed, huge leaks.
The valves are freshly set per guzziology
Petcock screen and fuel filters are good
« Reply #14 on: May 05, 2023, 07:20:29 AM »
Good points. Thats why I am only doing the mains at this time, tho I am due for airfilter cleaning/oil.
I am going to service the filters and swap the mains now, will leave the needles alone until I see where I stand.
Fuel delivery, valves, and exhaust leaks are all freshly checked and A-OK
« Reply #15 on: May 05, 2023, 07:21:15 AM »
 :boozing: Nice, thanks
« Reply #16 on: May 05, 2023, 08:38:42 AM »
My CX with 36mm carbs and a B10 cam has 130 mains and it runs perfectly fine, as Turin said, I would check the timing. Does it have points or electronic ignition?
Online PeteS
« Reply #17 on: May 05, 2023, 08:53:43 AM »
Main jets are all about WFO. Have you ever wound it out for a mile or two. My 850 came with 135 mains. It would barely pull 6800 in fifth after Manfred did his magic. I tried 138s, 140s, then 143s and now it will pull well over 8200.
If you are running ethanol fuel it runs even leaner.
40 HP seems way low. ‘60s era 650s could do that.
I think a better test would be to take to a dragstrip and see what it will do. LM850s were turning 13 seconds flat nearly 50 years ago. Built 950s should be able to beat that.
Online Moparnut72
« Reply #18 on: May 05, 2023, 09:32:42 AM »
You can do it.
Moto
A lot of Chrysler Theromoquads were thrown in the trash after being messed with. There is a very precise procedure for setting one up. The plastic body was usually blamed for the problem, claims they warped is unfounded. Follow the manufacturer's procedures and recommendations.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
« Reply #19 on: May 05, 2023, 09:42:07 AM »
Electronic, I've never had a points bike.
« Reply #20 on: May 05, 2023, 10:22:41 AM »
I have wound it out and it probably could use a larger main. It was mostly used as a commuter in the past but now that I'm not commuting I should install a bigger main jet but it doesn't feel anemic, except on hills which I have always thought that it was due to the lightened flywheel. Maybe a bigger main will solve that problem?
Online PeteS
« Reply #21 on: May 05, 2023, 10:43:25 AM »
Easily swapped on the road given the float bowl nut and you will know right away if there is a change for better or worse.
Pere
« Reply #22 on: May 05, 2023, 11:45:34 AM »
Pere
Yes, and I have some larger mains around here, as soon as I finish putting the transmission back together I'll give it a go.
Online John A
« Reply #23 on: May 05, 2023, 12:29:54 PM »
With that combination it should be reasonably quick in third from 50 mph on up to 7k rpm. You’ll get there, it got so I would want to tweak something before I went for a ride even after I got it running the way it should. As you get closer, the small changes make more subtle differences. Make sure you get the ignition super tuned to start. I had to laugh at myself when I started looking at a spare 44 amp magneto from our funny car. They probably take sixty horse to spin up and will hurt you, but you could ignite anything!
« Last Edit: May 05, 2023, 12:31:08 PM by John A »
« Reply #24 on: May 05, 2023, 06:03:26 PM »
Guzzi (and probably most all other manufacturers) were known to publish horsepower ratings that at best were optimistic. Claimed horsepower as measured at the crankshaft at optimal controlled conditions were likely still unobtainable in the real world.
My 72 Eldorado and 73 V7 Sport were both tuned on a dyno and the rear wheel horsepower on a fully rebuilt Eldorado (all stock) was right around 44 hp and the V7 Sport could (also fully stock and rebuilt) just touch 48 hp.
Put a Norton Comando or Triumph Bonneville of the same period on a dyno and I bet one would struggle to see rear wheel horsepower of 40.
Online cliffrod
« Reply #25 on: May 05, 2023, 07:33:09 PM »
Good thread & timing, Chad- no pun intended...  All this info is good to know.  finally getting my CX sorted & on the road is on the immediate agenda.  The details of the nearly new engine were a total mystery and the combination still isn’t “right” at this point.  I will be quite happy to have the engine tuned and performing as well as my V7 Sport.   Having another spot-on Guzzi with no stumble or hesitation, even if it isn’t the absolute fastest & flickable road burner on the road, is all I want.
Im guessing you hit the Dyno at the Meltdown last weekend(?).  We were camping at Table Rock with the in-laws, so I missed it.  Was it a good crowd?
« Last Edit: May 05, 2023, 07:33:57 PM by cliffrod »
Offline Don G
« Reply #26 on: May 05, 2023, 08:58:09 PM »
              Some good advice here, along with the enricher test. Sometimes with altered cams you may find it cheers up with the baffles out, check your exhaust system for restriction. Also air cleaners etc for same.  DonG
« Last Edit: May 05, 2023, 09:02:37 PM by Don G »
Online PeteS
« Reply #27 on: May 05, 2023, 09:38:15 PM »
Before getting hired at Barbers, Brian Slark was the Norton Club’s tech advisor. Along with Norton tuner Leo Goff they said a typical Norton Commando made about 47 RWHP. Race bikes might make 53-55 RWHP.
« Reply #28 on: May 05, 2023, 10:35:29 PM »
With respect to the Dellorto 36mm carbs, I put a new pair of Dellorto 36 pumpers on my 1975 Ducati 860 last year as that was all that Bevel Heaven could supply as they no longer stocked the 32mm stock carbs. The bike did not as well on the 36’s. I called Wolfgang Haerter the Laverda guru who also distributes Dellorto. Wolfgang was a wealth of information, to begin with he was supplying the new Dellorto’s to Bevel Heaven and these new carbs are jetted by Dellorto for Guzzi twins with the bigger valves specified for the 850 LeMans. Wolfgang said he had the stock 32mm Dellorto carbs in stock and they were better suited for the Ducati. Wolfgang had the correct specs for the 36mm Dellorto carbs for a Ducati 860 and sent me new atomizers, needles and jets, totally cured the Ducati.
Wolfgang told me the 36mm Dellorto carbs were too much for small valve Guzzi’s and Ducati 860 motors, better performance came from a 32mm carb.
For a 36mm Dellorto on a Guzzi, bigger valves, larger port diameter, bigger manifolds and exhaust diameter are needed to make use of the bigger carbs. The Guzzi LeMans and Mark II LeMans heads have bigger valves, ports, exhaust and manifolds.
Contacting Wolfgang at Columbia Car and Cycle in Nakusp British Columbia may be wort a call.
Offline chuck peterson
« Reply #29 on: May 06, 2023, 07:32:22 AM »
I’m thinking the phf 36’s are too big too, I think the vhb’s are all you should need
Pretty common to hear someone try bigger carbs as an upgrade
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
