Literally--------------------------I need that rod, cyl been locked unknown years, I been trying for 30yrs---------I even tried a 12ton press. My last resort. Just lucky piston was at bottom of skirt.
I had a V700 piston that stuck in the cylinder like that. I just cut the cylinder in half with my bandsaw (cut in from opposite sides, until I hit piston).
Sledge hammer and a few blocks of wood. I had a college teacher use that method to remove a stuck piston and surprisingly it was virtually undamaged and we reused it. Brute force is sometimes the simplest and quickest way, especially if the part you are trying to save is not going to be affected.
I'm just now needing the parts, used the crank & rods on a 700 w/bad oil pump. That motor also had a bad oil pump, maybe why it was junked.
