Author Topic: V7 - Replace brake/fuel lines every 4 years??  (Read 2026 times)
Offline cowtownchemist
« on: May 15, 2023, 07:16:27 AM »
Hey everyone, I have been reading the Routine Maintenance table in my 2014 MkI V7 owners manual and it tells me to replace both the Fuel lines and the Brake lines every 4 years.  This seems too frequent to me.
My question to you is how often do you replace your fuel/brake lines?
2014 V7 Stone
2000 V11 Sport
Re: V7 - Replace brake/fuel lines every 4 years??
« Reply #1 on: May 15, 2023, 07:21:55 AM »
Only once when changing the rubber lines to stainless steel on old barn finds. I would think changing the rubber lines on a new bike every 4 years excessive.
« Reply #2 on: May 15, 2023, 07:24:25 AM »
I am going to have to give you the "It depends" answer.
There are many factors that go into the degradation of those lines.
  • How much the bike is exposed to UV radiation
  • What type of fuel is used in the bike
  • How much sitting around does the bike do
  • How often is the brake fluid getting changed
  • What is the quality of materials used for fuel and brake lines
In my opinion those guidelines are partly to protect the manufacturer and to cover the worst case scenario.
If you do replace them, do some research and get quality replacements.  Stainless steel brake lines also improve brake performance.
Offline Kev m
« Reply #3 on: May 15, 2023, 07:45:25 AM »
I won't unless I find degradation upon inspection - weakness, swelling, visible damage, signs of leakage etc.
10 years on my lines so far for the MKI - no worries here. But my bikes do live under near ideal conditions regarding UV protection, and extremes of temperatures in a semi-heated (insulated) attached garage in a generally moderate climate.
YMMV.
Offline Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
« Reply #4 on: May 15, 2023, 07:48:56 AM »
6 years with the V7 II sitting outside all year, no signs of line failure yet. Front brake grabs solidly, but then again, I’m not the most acutely observant fellow. Will be adding steel lines when it comes time for replacement.
Offline huub
« Reply #5 on: May 15, 2023, 08:29:39 AM »
to replace fuel lines on a regular basis has been prescribed for ages.
a good thing to do anyway , just because old hardened fuel lines are a pain to work with
i've had rubber brake lines fail on 30 year old guzzi's , so 4 years sounds like on the safe side :-)
« Reply #6 on: May 15, 2023, 08:30:17 AM »
Ok, well I bought it last year and it only had about 2500 miles on it so it did a fair amount of sitting around.  However, it was garaged and well taken care of.  I have not seen any signs of leaking, however, since the lines are now almost ten years old I think I will just go ahead and swap the brake lines to steel.  That will give me peace of mind and I shouldn't have to worry about it again.
What about the fuel line?
2014 V7 Stone
2000 V11 Sport
Offline Kev m
« Reply #7 on: May 15, 2023, 08:55:56 AM »
MOTORCYCLE OEM's put a lot of things on the maintenance schedule that 99.99% of people DO NOT EVER DO.
They are there for strict liability reasons only - meaning if those items fail on a motorcycle the possibility for injury is much greater than on cars so they cover their asses.
I've been out of the auto industry for a while now, but I can't remember an automotive OEM ever recommending replacing fuel or brake lines prophylactically like we see on SOME motorcycle brands.
Personally I see no reason whatsoever to replace either UNTIL they show signs of age, which is why I said in my original post it's not something I do other than inspect.
I would feel different on an antique.
But 10 years is far from an antique.
« Reply #8 on: May 15, 2023, 09:06:03 AM »
I'm still running 1980 brake lines on a bike, they show no signs of breakdown at all.
I couldn't tell you how many times I've changed the fuel lines since 1988. :grin:
upload pic
« Last Edit: May 15, 2023, 04:55:39 PM by Guzzistajohn »
Online mechanicsavant
« Reply #9 on: May 15, 2023, 10:33:50 AM »
I’m pretty sure the OEM brake lines on a Mk II are stainles . They appear to have a vinyl coating , ya can feel the metal lining running your fingernail across them , or they are the thinnest rubber Ive ever seen or felt . I’d even bet a beer they have teflon tubing cores too
Offline Kev m
« Reply #10 on: May 15, 2023, 01:09:25 PM »
Yup  :thumb:
The MkI's do as well.
Yet another reason to not fix what isn't broken.
« Reply #11 on: May 15, 2023, 04:55:08 PM »
Yup  :thumb:
Words to live by.  :thumb:
« Reply #12 on: May 16, 2023, 07:06:21 AM »
Yes, I looked closely last night at my front brake lines on my Mk 1 and they do appear to have a braided stainless interior with a translucent vinyl outer covering.  I will not replace them.  The rear line is a black nylon or rubber line.  But it feels like the material is still soft and pliable so I will also leave it well enough alone and simply do a fluid flush.
Thanks for the comments!
2014 V7 Stone
2000 V11 Sport
