Author Topic: v7 850 oil change: torque specs?  (Read 4346 times)
Offline blackbuell
« on: May 19, 2023, 11:16:16 AM »
Changing the oil in my 2021 850 special. Checked the owner's manual, but couldn't find the torque specs for the oil drain plug and the oil filter cartridge screw. Anybody know them offhand?
Thanks,
Jon
« Last Edit: May 19, 2023, 11:17:21 AM by blackbuell »
Online Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
Re: v7 850 oil change: torque specs?
« Reply #1 on: May 19, 2023, 11:47:29 AM »
I don’t have one of those elusive E5 engine manuals in my library, but the V7 III engine manual states for:
Rear drain plug: 20-22 Nm (14.75-16.23 lb ft.)
Oil filter bolt: 18-22 Nm (13.28-16.23 lb ft.)
Seeing these are drain bolts threaded into an aluminum engine, probably just as fine simply hand-tightening followed by a wrench-tightening a hair past snug.
« Last Edit: May 19, 2023, 11:51:03 AM by Dirk_S »
« Reply #2 on: May 19, 2023, 12:02:26 PM »
THIS - USE CARE.
I no longer use torque wrenches on these items since Jay did and snapped his smallblock oil filter cap in half.
Offline blackbuell
« Reply #3 on: May 19, 2023, 12:19:19 PM »
Thanks Dirk and Kev
Jon
Offline mechanicsavant
« Reply #4 on: May 19, 2023, 03:19:00 PM »
Ah Ha ! So it is 1/4 turn “before” it snaps . Got it :boozing:
« Reply #5 on: May 19, 2023, 09:56:13 PM »
Tight is right
Too tight is broken
Offline Bulldog9
« Reply #6 on: May 20, 2023, 04:24:44 AM »
Snug e-nuf is how tight I go on things like drain plugs etc. They're a very few things that torque values are essential This would be head bolts, clutch/flywheel, etc. Most other fasteners it's not that critical.
MGNOC#23231
Online Perazzimx14
« Reply #7 on: May 20, 2023, 06:01:58 AM »
For drain plugs and small fasteners I use the longest cheapest clicker type torque wrench I can find with a 24" cheater on the handle and use red Loctite on anything threaded.
2017 Road Glide Special
2020 Kawasaki KLX300SM
Online Dirk_S
« Reply #8 on: May 20, 2023, 06:48:02 AM »
You pulled the girls’ pigtails and stuck frogs into their lunch bags when you were little, didn’t you.
Offline sib
« Reply #9 on: May 21, 2023, 09:09:23 AM »
I prefer to use an impact driver intended for truck wheel bolts.  Tighten until the drain plug spins freely.
Current: 2021 V7 Stone E5
Previous: 2016 V7II Stone
Previous: 2013 V7 Stone
Offline Off @ 90
  • Heron Head Heretic.
« Reply #10 on: May 21, 2023, 03:04:41 PM »
These torques seem way too high for aluminium threads in the rear drain .Mk2 book states 12NM for drain plug .I use that for oil filter too and pretty sure the Mk3 has the same filter housing.
Duncan
Online Dirk_S
« Reply #11 on: May 21, 2023, 04:11:03 PM »
Hey now, don’t hate the messenger! Here are screenshots from the V7 III engine manual:
I’m curious where you found the torque specs for the V7 II—I did a couple quick scrolls through both service and engine manual, and only found torque spec for the front drain bolt.
Offline Vagrant
« Reply #12 on: May 21, 2023, 04:33:15 PM »
That come from the same people who tell you to put in over two quarts of oil in the engine.
« Reply #13 on: May 21, 2023, 04:59:49 PM »
If my career in technical publishing has taught me anything, it's that you don't blindly trust any manual. You look with a critical eye at every spec, like that Chevy Corvette manual I was working with that suggested a negative main bearing clearance...
I probably find more discrepancies in torque specs than anywhere else.
PS, I'm pretty sure that was the torque spec Jay was following when he split his filter cap.
Online Dirk_S
« Reply #14 on: May 21, 2023, 05:59:34 PM »
Good point. Snowbum, the well-known (albeit largely unorganized) Airhead expert points out on his webpages that older BMW manuals sometimes had incorrect imperial torque specs (which is why I now pay attention to the manufacturer’s country of origin and subsequent default unit of measure).
Offline Dr. Enzo Toma
« Reply #15 on: May 22, 2023, 12:35:50 AM »
Ducati have gotten drain plug torque specs incredibly wrong before, it happens.
https://www.ducatiscramblerforum.com/threads/nasty-mistake-workshop-service-manual.10002/
For someone who's just looking to do an oil change on their bike (good for them!) and doesn't wrench enough to have a concept of torque specs, but are trying their best and following a manual, that can unfortunately go sideways.
MGNOC Member
