Author Topic: Dave Moss tunes the suspension on a Griso  (Read 3730 times)
« on: June 02, 2023, 09:48:58 PM »
https://youtu.be/ZZoHFCPqoq8
Nice comments about the bike.
Online Bulldog9
Re: Dave Moss tunes the suspension on a Griso
« Reply #1 on: June 03, 2023, 11:46:57 AM »
Interesting.
For those interested (data geeks) here is a spread sheet I keep this stuff in. Just added Dave Moss's setup for comparison.
**Settings for all compression and rebound is COUNTER CLOCKWISE from fully closed.
                                      STOCK BD1   BD2  GG   Dave Moss
FORK Tubes (rings showing)    1   2   2   2   2
FORK Preload (rings showing)   4   4   5   4   5
FORK Compression (bottom)   1   1   .75   .25   2.25
FORK Rebound (top)                1.5   1.5   1   2.25   1.33
REAR Preload (threads showing)   12   15   15   15   17
REAR Compression (top)          .25   1   .75   .25   1
REAR Rebound (bottom)           17   30   25   40   21
I'm Running BD2 right now and like it very much, but will try out Dave Moss's settings. I found his front compression settings a bit odd, but with increased preload may even out.
The Griso can be an awkward fat girl or lithe athlete depending on suspension settings and tire pressures.
MGNOC#23231
Offline lazlokovacs
« Reply #2 on: June 03, 2023, 12:22:54 PM »
it's like christmas watching dave work on a griso!!!
why anyone would ride a griso with anything less than 6 rings showing on the forks is a mystery to me though!!!
also, the bit where Dave is literally on his knees counting all the settings he's just done for the guy, who decides it's a perfect moment to get out his phone and write a text and stop listening to him.  :huh:
Offline Huzo
« Reply #3 on: June 03, 2023, 06:14:44 PM »
I’ll admit that it’s an area I’m not all that conversant with. I have NEVER altered the settings on my Nitron shock that I fitted @ 90,000 km and now it has 210,000. I just seem to have all the fun on the bike that I’m ever likely to, without feeling the need to buggerise around with micro adjustments.
Same with the Ohlins on the V85, it seems to do all I want straight out of the box.
I’ve seen a LOT of guys trying to sell snake oil to wide eyed owners by “tuning” their suspensions.
Look…
I’ll readily admit that there was a time where if Valentino Rossi’s suspension technician was left alone with my MV Agusta and did NOTHING, I would have ridden off and convinced myself that it was better. Maybe this guy is all he appears to be, so that is absolutely fine with no hint of derision.
If VR himself took your bike out at Mugello and clocked a time, then after some “adjustments” went out and did 2 seconds better, you’d think it was great and no doubt cuddled up to the plastic wrapped photo of him on YOUR bike with the shredded tyres, that night… :wink:
I just think there is a large opportunity to tell guys what they want to hear and relieve them of cash for the privilege. If our guy tunes your suspension and watches you do some laps, he only has to tell you that you were 3 seconds faster and you’ll believe it, if you are prone to that kind of thing.
But like anything, if you feel better then it’s been worth the money.
« Last Edit: June 03, 2023, 06:20:11 PM by Huzo »
Offline lucian
« Reply #4 on: June 03, 2023, 08:11:58 PM »
What I found astonishing is that he never confirmed the tire  pressures. As a Griso owner since 2015 I can say with confidence that the front tire pressure is the most influential factor in the bikes front end behavior.  After that ,fork height above tree, sag or preload ,and the compression and rebound damping , in that order , are all well worth the trouble to fine tune. But on a Griso all will be in vane if the front tire is down on pressure even a pound or two. Maybe he did and it just wasn't shown? The complaint of heavy steering immediately made me want to check his front tire psi.
Online Bulldog9
« Reply #5 on: June 03, 2023, 08:16:57 PM »
Look…
I've been largely the same, but the Griso is different.  Is WAY too easy to have a goofy setup and a bad handiling bike than any other I've owned.  I was fortunate to buy mine used from a known Guzzi specialist, so it was set u optimailly, but I have helped dozens of Griso owners take their bike from clumsy to nimble just buy setting the suspension for THEM.  Perhaps I am sheltered, but the Griso has the most adjustible suspension of any bike I've owned, and it took a while to get it dialed in including tire pressure.  yMmV
MGNOC#23231
Offline kidsmoke
« Reply #6 on: June 04, 2023, 07:56:27 AM »
Bulldog, can I assume you’re experience tells you stock suspension is adequate with proper tuning?
Just getting to know my GRiSO, and this is of great interest to me.
Blew out a fork seal immediately upon taking ownership, so I had them replaced and 5weight oil used. 4(outer tube rings) above the tree.
Yesterday did 160 miles to find my license plate curled up under the seat (tail tidy equipped) so compression on the rear clearly needs attention! <200#
« Last Edit: June 04, 2023, 08:01:02 AM by kidsmoke »
'79 G5      (Gina)
'93 1000S (Monica)
'00 Jackal  (Claudia)
'09 GRiSO  (Perla)
Offline red lion
« Reply #7 on: June 04, 2023, 02:19:30 PM »
I'm sorry but what does BD1- BD2 and GG stand for?
Online Bulldog9
« Reply #8 on: June 04, 2023, 04:16:56 PM »
I find it fine, though there are many who say the whole suspension is garbage and throw in/on $3000 worth of bits.
MGNOC#23231
Online Bulldog9
« Reply #9 on: June 04, 2023, 04:19:41 PM »
BD1 is the first settings I tried and was basically how the bike came being set up at Moto International for the prior owner.
BD2 is what I use when I KNOW I am heading for twisties and track or canyon carving
GG is a setup one of the guys on the Griso Ghetto recommended.
MGNOC#23231
Offline PilotJet
« Reply #10 on: June 05, 2023, 05:13:29 PM »
Interesting.
Thanks for this Good Info.
Online PJPR01
« Reply #11 on: June 05, 2023, 10:00:35 PM »
Before going hog wild on a full blown new suspension, depending on your weight, adding a stiffer spring from HyperPro goes a LONG way to solving the soft rear suspension.
Then, couple that with a proper sag and preload setup, and of course proper tire pressures, and the Griso is transformed.
If that doesn't work, go to town with a Wilbers or Matris for the rear, and possibly some HyperPro front springs, heavier weight oil, but you don't have to spend a fortune to get the bike properly setup...try it in increments first.
Paul R
2015 Red/Black Griso
2008 Silver Norge
2002 V11 Scura
Offline tazio
« Reply #12 on: June 06, 2023, 05:19:44 AM »
I followed Paul's advice above in going with the heavier Hyperpro rear spring. I'm at 240lbs of quivering flesh and the stock spring had sprung (so to speak) :boozing:
Stock spring was too soft for me..
Now it's Purple Power.Yeah,baby!
I removed mine going out the top, though I wonder if going out the bottom may have been easier...
1967 Kawasaki 650 W2TT
1966 Triumph Bonneville
Offline drawnverybadly
« Reply #13 on: June 12, 2023, 10:48:39 PM »
Hey Tazio, can you share the product code for the spring that you bought?
Offline tazio
« Reply #14 on: June 13, 2023, 04:47:21 AM »
Spring #1224
I think I spoke to Mike Medeiros.
EPM Performance Imports is the HyperPro importer for the USA
Email: sales@epmperf.com
Phone/ Fax: 732-786-9777
www.epmperf.com
Hope this helps.
« Last Edit: June 13, 2023, 04:51:38 AM by tazio »
