Author Topic: Le Mans IV Dash Removal  (Read 1302 times)
Offline cjl
« on: June 12, 2023, 07:22:08 PM »
Looking for some assistance in replacing some dashboard light bulbs on my 1986 Le Mans IV!
I've gone through some manuals, but can't seem to locate how exactly to get to the indicator lights safely without breaking anything. I've read that the the key bevel must be removed first, but it doesn't seem to be a removable piece - unless I'm missing something.
Appreciate any help!
Chris
Not my photo, but here's the exact dash just for reference:
Offline Bazil
Re: Le Mans IV Dash Removal
« Reply #1 on: June 12, 2023, 10:37:50 PM »
It's a bit of an exercise, from memory its :
 - fairing off
- remove tacho & speedo cables
- loosen nuts under the rubber cover, allowing the whole assembly to be moved
- undo screws holding on back cover, and ease the cover off
behold ! - all the entrails are revealed.
lamps are tiny wheat globes in plastic holders and they are awkward to get to. Pliers and patience needed.
Make sure you don't use an LED for the generator lamp, or battery wont charge !
While you're in there, make shiny and de-Oxit all the connectors as best you can
A good way to spend a wet afternoon...
1986 Lario ( long gone, still missed)
1985 Mark IV Lemans ( Gina)
1991 V40 Targa ( L'il Jeannie)
1962 Royal Enfield Crusader Sports
Offline cjl
« Reply #2 on: June 13, 2023, 12:15:43 PM »
 - fairing off
Can't thank you enough! This is a tremendous help.
Now if I can only find a front brake master cylinder gasket that doesn't leak..
Offline guzziart
« Reply #3 on: June 13, 2023, 02:34:43 PM »
Yeah, good luck with that, if you do find someone with inventory, please post.
Art
