Author Topic: getting bar end weights to stay in place  (Read 1730 times)
Offline lazlokovacs
« on: June 13, 2023, 03:02:41 PM »
So for many years I've used long shouldered M6 bolts with whatever bits of rubber tube I have left and a washer to hold my bar ends in place. Though this never quite seems satisfactory as they tend to loosen over time and/or the rubber disintegrates. The very best set up I ever had was on the lemans 1000 whose bar ends had a long steel tube integral to the bar end with a conical tapered nut that expanded the steel tube.
What are you guys using? My google skills aren't up to finding a neat solution, in the past I've just ordered a cheapo set of bar ends, thrown them away and just used the rubber bit on whatever bar ends are best suited for that bike. Is that the best I can do?
Hopefully someone else has BTDT
thanks as usual
Online PeteS
Re: getting bar end weights to stay in place
« Reply #1 on: June 13, 2023, 05:28:02 PM »
The expanding nuts on my ‘98 EV gave up within the first year. Guzzi wanted $70 for a replacement bar end.
I ended up machining an aluminum plug with a press fit into the bar and drilled and tapped for the bolt. Never a problem after that. Also machined new bar ends out of Aluminum.
That was my introduction to Guzzi parts pricing.
Offline wrbix
« Reply #2 on: June 13, 2023, 05:43:21 PM »
Expanding sleeve with blue LocTite on both the bolt and outside of sleeve.
Blue LocTite holds my world together.
Bill in VA, sometimes FL
"Eschew aphorism"
LeMans IV - "Giulia"
Lario - "Giulietta"
V50III cafe'd - "Leggera"
‘77 Convert - “Sofia”
Classic Mini
‘60 Austin Healey Sprite
Caterham Super Seven Sprint
‘13 Audi TTRS
Grumman AA5B (sold)
Offline wirespokes
« Reply #3 on: June 14, 2023, 12:10:08 AM »
I always thought the internal bicycle seat clamp was the best idea. Machining an aluminum plug, drilled and tapped is a good idea. But I don't understand why bar ends would be needed or wanted, unless to compensate for poor tuning. These bikes are so smooth I see no need for them on my  bikes.
Offline Stretch
« Reply #4 on: June 14, 2023, 05:13:09 AM »
THIS!    ^^^
I have a KLR650. I wonder what the total weight of blue LocTite is on that machine........
                                                             -Stretch
1967? Change Jiang M1M
1978 Yamaha SR500
1971 BMW R75/5
1987 BMW K75S
2011 Kawasaki KLR650
2015 Triumph Trophy
Offline Scout63
« Reply #5 on: June 14, 2023, 06:10:21 AM »
THIS!    ^^^
                                                             -Stretch
Blue Loctite is my adult paste. I’ve eaten a fair bit just holding the cap in my mouth. It’s not bad.
Ben Zehnder - Orleans, MA USA
Offline lazlokovacs
« Reply #6 on: June 14, 2023, 06:21:21 AM »
dude!!!! don't eat that stuff!!!!!
thanks for the replies
Offline Stretch
« Reply #7 on: June 14, 2023, 08:20:26 AM »
Hey - I just remembered I've got a set of internal expanding sleeves and
bolts leftover from a bark buster kit I got for the KLR. I don't need 'em.
You can have 'em gratis.
Shoot me a PM if you want 'em.
                                                     -Stretch
1978 Yamaha SR500
1971 BMW R75/5
1987 BMW K75S
2015 Triumph Trophy
