Author Topic: '17 V7III Special dead tach blues  (Read 1020 times)
Offline Ronkom
    • Virginia Moto Guzzi Owners Club
« on: June 26, 2023, 08:49:49 AM »
The factory wiring set-up for the tach on my V7 is odd in that there is a hot lead direct from the battery (through a fuse) to the tach that is hot ALL THE TIME (key on or off). Of course mine has died & I discovered the odd wiring trying to put a new fuse in and having it fry on contact. So, a new tach is well over $500.00, (ouch), & all the used ones I've seen so far were damaged in the crashes that caused the bikes to be parted out.  I'm on several Guzzi forums & remember seeing a posting identifying the electrical component inside the tach that has failed causing the direct short/dead tach. Apparently it is inexpensive & can be replaced if the tach housing  can be opened & then resealed w/out breaking the glass etc. Unfortunately I didn't make note all this info at the time, and now can't find it. Can anyone help?
Thanks,
Ronkom
PS the tach part # is 2D000294 and is used on the 2017-18-19 V7 dual gage models, and I believe on newer 850 models.
THE MOTRESYKLMAN
Offline Turin
Re: '17 V7III Special dead tach blues
« Reply #1 on: June 27, 2023, 09:39:47 PM »
I wanted to have my cal III tach fixed. Nobody repairs electronic Tachs domestically. There may be someone in England or the Viking lands that do that stuff. I opted for speedhut tach. you can customize them and they are about $200.00
1985 Sidlow Guzzi
