Author Topic: V7 III rocker pin fork screw torque  (Read 1067 times)
Offline dublicious
    • None
« on: July 12, 2023, 05:36:32 PM »
Hello! Curious if anyone has any info on the torque specs missing here? Specifically pos. 3&4. The ones locking the pin fork had loctite on them. Is this an indication that specific torque isn't super important (since it's just holding the fork down) and it's a matter of putting loctite on and snugging up? Seems sketchy but unless there's another way to get this info, I'm not really sure that else to do. Pic of manual diagram attached. Hopefully that's readable...
Thanks!
Online Tom H
Re: V7 III rocker pin fork screw torque
« Reply #1 on: July 13, 2023, 12:47:56 AM »
You might want to measure the bolts and look up the specs for that size. Use loctite and tighten a little less than spec.
Just a thought,
Offline dublicious
    • None
« Reply #2 on: July 13, 2023, 08:04:03 AM »
Just a thought,
Thanks Tom, that's a good thought!
Offline nc43bsa
« Reply #3 on: July 14, 2023, 01:46:53 AM »
Don't follow the "tighten it until it breaks, then back off 1/6 turn" rule.    :evil:
« Last Edit: July 15, 2023, 01:40:01 AM by nc43bsa »
1990 MilleGT
« Reply #4 on: July 18, 2023, 12:58:26 PM »
Ahh, Guzzi torque specs. Obviously, these fasteners require no torque at all.. :evil: that's what the manual says.  Maybe you look at them fiercely and say, "Stay."  :smiley:
