Author Topic: V7 2012 1TB: Obscure error code P0530  (Read 1642 times)
Offline lewisham_phil
« on: July 17, 2023, 09:22:02 AM »
Does anyone have a definitive list off Guzzi V7 error codes? My amber engine light is on full time, though no change in engine characteristics (I have been trying to sort out a long term decel popping with Beetlemaps, and have just installed a pair of Mistrals with no Db killers..).
I've just had a look with Guzzidiag, and am getting two error codes; P0611 'invalid signal' which is a data buffer full code, which I understand is to be ignored; But also there is a P0530 'No signal' code, for which I can find no information anywhere; manuals, web...
I have asked Beetlemaps Mark, but it's the early hours in Australia at the moment, so just being a bit impatient thought I'd ask here.
Thanks in advance.
Phil
Previous bikes: CB200-RD350-GS550-CBX550-DT250-FZ750-RD250LC-ZZR600-CB919-XY400-Guzzi V7I Special
Offline SportsterDoc
Re: V7 2012 1TB: Obscure error code P0530
« Reply #1 on: July 17, 2023, 09:41:39 AM »
Not finding a P0350 unless for an automotive refrigerant system
ECU Error Code 10 - Error throttle valve C.C. Vcc
ECU Error Code 11 - throttle valve C.C. Gnd
ECU Error Code 12 - Some analog channel functions do checks on the input signal to make sure it is changing as expected (i.e. RPM and MAP are increasing but TPS did not change or engine idling but TPS at 100%)
ECU Error Code 13 - Temp Sensor disconnect?
ECU Error Code 14 - Engine temperature C.C. Vcc
ECU Error Code 15 - Engine temperature C.C Gnd
ECU Error Code 16 - Air temperature C.C. Vcc
ECU Error Code 17 - Air temperature C.C Gnd
ECU Error Code 20 - Low battery
ECU Error Code 21 - Lambda sensor (02 Sensor)
ECU Error Code 22 - Ignition coil 1 C.C. Vcc
ECU Error Code 23 - Ignition coil 1 C.C. Gnd
ECU Error Code 24 - Ignition coil 2 C.C. Vcc
ECU Error Code 25 - Ignition coil 2 C.C. Gnd
ECU Error Code 26 - Injector 1 C.C. Vcc
ECU Error Code 27 - Injector 1 C.C. Gnd
ECU Error Code 30 - Injector 2 C.C. Vcc
ECU Error Code 31 - Injector 2 C.C. Gnd (This is not listed but I suppose that this is the function)
ECU Error Code 36 - Pump relay
ECU Error Code 37 - Local Loop-back
ECU Error Code 44 - Relay starter C.C. Vcc
ECU Error Code 45 - Relay starter C.C. Gnd
ECU Error Code 46 - Canister C.C Vcc
ECU Error Code 47 - Canister C.C. Gnd
ECU Error Code 50 - Battery high
ECU Error Code 51 - ECU general
ECU Error Code 54 - Instrument panel
ECU Error Code 55 - Autoadaptation Tito I (I have no idea what this is.)
ECU Error Code 56 - Vehicle speed
ECU Error Code 60 - Stepper C.A.
ECU Error Code 61 - Stepper C.C. Vcc
ECU Error Code 62 - Stepper C.C. Gnd
ECU Error Code 00 - Unknown
DASHBOARD ERRORS
DSB 01 - Immobiliser fault: key code read but not recognised or key code not read
DSB 02 - Key not present or transponder broken
DSB 03 - Immobiliser fault: Antenna broken (open or short-circuit)
DSB 04 - Immobilizer fault: internal controller fault
DSB 05 - Fuel sensor fault
DSB 06 - Air temperature sensor fault
DSB 07 - Oil sensor fault DSB
DSB 08 - Oil pressure fault
C1100 = Front speed sensor missing signal or speed measured too low in relation to the rear wheel.
C1102 = Front speed sensor: missing signal or speed measured too low in relation to the rear wheel.
C1104 = Front speed sensor: missing signal or different speed measured at the two wheels.
C1106 = Front speed sensor: missing signal or different speed measured at the two wheels.
C1108 = Front speed sensor: the signal works irregularly
C1110 = Front speed sensor: the signal decreases periodically
C1301 = Failed CAN reception from instrument panel
C1302 = CAN line mute mode
P0105 = rear cylinder air pressure sensor
P0106 = front cylinder air pressure sensor
P0107 = rear cylinder air pressure sensor
P0108 = rear cylinder air pressure sensor
P0110 = air temperature sensor
P0115 = engine temperature sensor
P0116 = engine temperature sensor
P0120 = potentiometer 1 sensor, rear throttle position
P0121 = potentiometer 1 sensor, rear throttle position
P0122 = potentiometer 2 sensor, rear throttle position
P0123 = potentiometer 2 sensor, rear throttle position
P0124 = rear throttle position potentiometer
P0125 = potentiometer 1 sensor, front throttle position
P0126 = potentiometer 1 sensor, front throttle position
P0127 = potentiometer 2 sensor, front throttle position
P0128 = potentiometer 2 sensor, front throttle position
P0129 = front throttle position potentiometer
P0130 = Oxygen sensor
P0134 = Lambda probe - voltage without variation.
P0135 = Lambda probe heating
P0136 = Right lambda sensor heating
P0141 = Lambda shorted to positive / open circuit,
P0150 = Blue lower connector throttle grip position sensor - track A
P0151 = Blue lower connector throttle grip position sensor - track B
P0152 = White upper connector throttle grip position sensor - track C
P0153 = White upper connector throttle grip position sensor - track D
P0154 = Blue lower connector throttle grip position (tracks A-B) - illogical signals.
P0155 = White upper connector throttle grip position (tracks C-D)
P0156 = Throttle grip position
P0160 = Rear throttle Limp Home self-acquisition
P0161 = Rear throttle mechanical springs self-acquisition
P0162 = Rear throttle minimum mechanical position self-acquisition
P0163 = Detection of the rear throttle Recovery conditions (air temp., water temp.)
P0164 = Rear throttle power supply voltage during self-learning
P0165 = Front throttle first self-learning NOT performed
P0166 = Rear throttle control circuit
P0167 = Rear throttle position error
P0168 = Throttle body learning procedure can not be executed
P0169 = Starter switch LOGIC ERRORS
P0170 = Starter switch ELECTRICAL ERRORS
P0180 = Front throttle Limp Home self-acquisition
P0181 = Front throttle mechanical springs self-acquisition
P0182 = Front throttle minimum mechanical position self-acquisition
P0183 = Detection of the front throttle Recovery conditions (air temp., water temp.)
P0184 = Front throttle power supply voltage during self-learning
P0186 = Front throttle control circuit
P0187 = Front throttle position error
P0190 = Exhaust butterfly valve position
P0191 = Exhaust butterfly valve stop research
P0192 = Exhaust valve engine
P0193 = Exhaust valve potentiometer
P0195 = Engine Oil Temperature (EOT) Sensor Malfunction
P0210 = Error for unexpected air intake in the rear cylinder manifold
P0211 = Error for unexpected air intake in the front cylinder manifold
P0215 = Estimation error for rear cylinder intake manifold pressure
P0216 = Estimation error for front cylinder intake manifold pressure
P0217 = Pressure too low at rear cylinder manifold error
P0218 = Pressure too low at front cylinder manifold error
P0230 = fuel pump relay control
P0335 = Crankshaft Position Sensor A Circuit malfunction
P0336 = Engine speed sensor
P0351 = Coil 1
P0352 = Coil 2
P0410 = Secondary Air Injection System
P0446 = Secondary air valve control
P0461 = Gear sensor
P0501 = Front wheel speed/ABS signal/sensor
P0502 = Rear wheel speed/ABS signal/senor
P0505 = Idle Control/Stepper Motor
P0510 = Rear wheel radius acquisition
P0512 = Starter switch
P0560 = Battery voltage
P0601 = EEPROM Error
P0604 = RAM Error
P0605 = ROM Error
P0607 = A/D converter
P0608 = Level 2 safety reset
P0609 = Safety Engine Stop
P060B = A/D converter
P060C = Engine safety stop
P0610 = Stop lights relay error
P0611 = Saved data file (for safety)
P0615 = Starter relay
P1301 = Stop lights relay error
P1601 = CAN bus
P1602 = Cylinder bank intake manifold pressure estim. Error
P1607 = Data file saved (for safety)
P160C = Level 2 safety reset
« Last Edit: July 17, 2023, 09:42:29 AM by SportsterDoc »
23 V7-850 23 Yam XT250 18 Yam Bolt  22 Triumph St Twin  20 CanAm Ryker 14 Honda CB1100 18 Yam XT250 16 MG V7II 17 Yam TW200 12 Triumph Bonnie 02 Sportster 1200S 03 Sportster XLH883 76 Honda 750F 75 Honda CB360 70 Yam CT1 72 Yam CT2 72 Yam AT2 70 Honda SL350 70 Honda CL350 67 Honda CL160 67 Honda C11
« Reply #2 on: July 19, 2023, 07:10:01 PM »
Thanks Doc. I've cleared the fault using Guzzidiag, under instruction from Mark/Beetle, who also didn't recognise the code. It erased Successfully, and it hasn't re-appeared, so hopefully not vital, whatever it is/was. I did notice, while playing with Guzzidiag, that the RH Lambda sensor was reading 0mV, as opposed to the LH sensor, which had a reading, so it has obviously failed. I know these are disabled anyway using a beetle map, so it doesn't matter.. but maybe a clue to the mystery error code.
« Reply #3 on: July 20, 2023, 07:19:07 AM »
Glad it cleared and hope it stays cleared.
« Last Edit: July 20, 2023, 07:19:54 AM by SportsterDoc »
