Author Topic: worn distributor gear on loop  (Read 1244 times)
Offline ray bear
« on: July 23, 2023, 02:16:10 AM »
Doing some work on my mates 850GT and come across excessive wear on distributor drive gear and on only half of the teeth on 1 side as if the shaft is bent, 3 of the teeth are becoming almost knife edge, looking at camshaft all appears well and if cam had an issue it would effect all teeth on distributor. I will remove shaft and see what a dial indicator shows but maybe someone has dropped it at some stage , turning it insitu appears to be no run out but my eyes arent that good. also distributor shaft has 29 thou end float which is excessive according gregs site  and still has original pin, so dont think anyone has been there before me.  Can some one shed some light on this please ,thanks for replies Ray
« Last Edit: July 23, 2023, 02:16:40 AM by ray bear »
73 V7 sport
73 Eldo police special
68 BSA rocket 3
74 Norton Commando
78 Honda CBX 1000
47 HRD vincent Rapide
XT 500 Yamaha
Online Tkelly
Re: worn distributor gear on loop
« Reply #1 on: July 23, 2023, 07:36:07 AM »
I had a t3 that had a lot of miles on it and had that problem.The points kept getting out of adjustment until a guy figured out what was wrong,apparently worn out.
Offline guzziart
« Reply #2 on: July 23, 2023, 08:23:46 AM »
Hi RB,
When I went through my Eldo distributor the end play was excessive too.  As I recall I got shims & roll pin from McMaster-Carr (stateside) but someone in the Down Under area might have them too.  I can't help with the gear though but would be reluctant to re-use it if wear is noticeable.  While you are in there, you may want to replace the ignition advance springs too, I believe guzzilogy recommended spring part numbers or maybe they're posted at This Old Tractor.  If you can't source the shims & roll pin locally, pm me and I'll try to see if I still have those things around....I did mine over a decade ago.
Art
Offline ray bear
« Reply #3 on: July 24, 2023, 12:20:38 AM »
thanks for the input chaps, the gear had a noticeable run out , i suspect someone has dropped it , never mind had an old one that have rebuilt all good , Ray
73 V7 sport
68 BSA rocket 3
74 Norton Commando
78 Honda CBX 1000
XT 500 Yamaha
