Author Topic: eratic ignition fault with 850 GT loop  (Read 871 times)
Offline ray bear
« on: August 05, 2023, 11:14:24 PM »
I occasionally read threads here about people that are having difficulty finding ignition faults, Have been helping a friend with erratic behaviour with his 850GT and done all the usuals such as condenser, coils, plugs caps rotors etc to no avail but this morning disconnected the tacho wire from the coil and Bingo  all good, the tach worked well but obviously some thing astray inside so hope this may help others from tearing what's left of their hair out. Incidentally when we replaced the condenser it run well for a little while then played up again but may have just been a coincidence Ray
73 V7 sport
73 Eldo police special
68 BSA rocket 3
74 Norton Commando
78 Honda CBX 1000
47 HRD vincent Rapide
XT 500 Yamaha
Re: eratic ignition fault with 850 GT loop
« Reply #1 on: August 06, 2023, 08:33:31 AM »
I had one that was going around w/issue, I never thought of that wire. I got rid of points & condenser and put in a lectronic ignition & that fixed it. Never thought of the tach being the issue. GOOD Catch.
Online bigbikerrick
« Reply #2 on: August 06, 2023, 10:17:54 AM »
These ignition issues can really be difficult to sort at times. Good find!
Rick.
Offline Don G
« Reply #3 on: August 06, 2023, 09:18:43 PM »
The first thing I do when having ignition problems is reach under the dash and pull the wire off of the tach to see if it cheers up. DonG
« Reply #4 on: August 06, 2023, 11:23:21 PM »
I remember that it was not uncommon for the electronic tach to make ignition problems on a loop. I don’t remember what made it happen but I think it was the first sign of a failing tach.
