Like I said, powdercoat. My snowflake wheels were done with it and after a good few years it started to flake in a similar way to your photo. The corrosion gets under it and then it separates the two.And it's a real bugger to get off where it's still holding on too !!
And you can heat and form them for 'special' applications!
As for bearing races I've had good results using the dremel only to form a notch, then a sharp smack with a chisel to crack the race. Then they tap out easy or fall out in pieces.
Have you had success with the small but nightmarish swing arm bearings with this method, per chance Dguzzi?
Ouch!!Good work with the dremel so far.For my R75/5, I had to make a few angled cuts close together, then try to crack out the bit between the cuts. A lot of patience is required.Tom
My tool of choice for those is a blind hole bearing puller. The largest collet is just right.
If you ever have to take a complete carrier bearing out. I found that a steel rod of about 4'/1.3m long that just fits down the swing arm gets the job done with a few stout jabs downward with the U joint area firmly on a cement slab.Tom
What a pig of a job........
Is that with no heat being used Charlie?
Yep.Kudos for keeping on. I'm sure you can't wait until it'sback on the road and running like a top! -Stretch
No heat used to remove the swingarm pivot bearings (or u-joint carrier bearing either, for that matter). I've only done Loopframe and early Tonti-frame Guzzis though.
I would consider pulling that swingarm to get a better shot at it. I know many people will weld a few beads across the inside of the race and that shrinks the race a bit to release easier.
On which point ,.. Is there an special spec to the swing arm bearings Charlie?I gather it's a tapered roller bearing, original spec being 17mm i/d, 40mm o/d x 12mm depth, but on Gregory Bender's 'this old tractor' site he says ..."The following physical dimensions are slightly thicker, but work just fine and are much easier to source than the original (thanks to Fred on the old Yahoo! Loopframe_Guzzi news group (which has now moved to Groups.io) for confirming the fitment).Inside diameter: 17 mmOutside diameter: 40 mmWidth: 13.25 mm.."Which works out as SKF 30203j2Do you know if this means the spacers on the outside of the swing arm bearings have to be thinned by 1.25mm to accommodate the wider bearing?Or is there a simpler answer? I've seen prices for swing arm bearings ranging from nearly £90 each to just £15 for SKF versions, which i find very confusing
I use the 30303 bearings without any modifications or issues. The pivot pins just won't thread in quite as much (barely noticeable).
Ah fantastic, thanks for clearing that up.Also, if I may, as it's an unsealed bearing, I'll need to replace the seals 30mm i/d x 40mm o/d x 7mm thickness. I see cheap ones, although listed as high quality at £2.50, and SKF seals of the same spec at £6.50The main question I have though, is that they come in both single, or double, lip construction. Is there a preference in our particular application? . . . And do forgive my ignorance, but what stops the grease from leaking from the internal side of the s/arm bearings?Having been intrigued, I realise now, when you said you've only done loop and early tonti's, that the v11 uses a different bearing arrangement altogether for the swing arm I'll try the conventional slide hammer puller rather than having at it with the dremel'ish tool I'm just wondering if I can find a second hand bearing press kit going cheap now (strokes chin)
Corrected my bearing number 30203, not 30303. The seals aren't under any pressure, so even the cheap seals will do the job. Single lip seals are all that's necessary. I do like to polish the o.d. of the spacer they seal on, so it's clean and shiny. On the driveshaft side, the back/internal side is blanked off by the round section the u/j runs inside. On the left side it's open into the crossmember of the swingarm (although that too ends at the round section the u/j runs inside of), so a little extra grease isn't a bad idea. I spray the inside of that tube with a little chain lube to ward off rust. AFAIK, the 1100s use the same bearing arrangement as the earlier models.
Your quickly shedding your novice standing into expertise by entering the fight with only sheer determination on your side…Go man, go! I’m pulling for you!
For installing the carrier bearing.....Keep at it!!!!!Tom
Check your sockets IO.One of them will be a suitable diameter if you have your lucky pants on
