Author Topic: t3 gearbox "slipping"  (Read 1927 times)
Offline siabeid
« on: September 18, 2023, 04:45:34 PM »
My T3 gearbox has begun to act very strangely. I am hoping that someone may have an idea of how to proceed before I start tearing things apart. Despite all of the miles on the Guzzis that I have owned, I have never had a problem with a transmission, and have only had one apart when I was resurrecting my v7 Sport. At that time, I was only checking for wear  and replacing seals and bearings, and there were no other problems with that one.
The T3 has 50,000 miles on it. I have had it since 1999. I replaced the clutch at around 40,000 miles. Everything has been working as it should, until recently. Lately, about half the time when I shift into 2nd gear, it sort of "slips" before it positively engages. It feels like an old automatic transmission when the bands would slip. It does this both upshifting and downshifting. It never does it in any other gear, nor does it make any strange noises. It doesn't always misbehave, either. I drained the oil and also put a slim magnet into the box, but got no metal particles out. I thought perhaps it had sheared some teeth or maybe a bearing is going bad. The linkage was pretty worn out, so I replaced that. It greatly improved shifting in all gears, but still the "slipping" in 2nd gear persists. All other gears are fine. Any ideas?
Siabeid
Kettle Falls, WA
Re: t3 gearbox "slipping"
« Reply #1 on: September 18, 2023, 05:12:51 PM »
No I don’t.
But great to hear from you again… :bow: :thumb:
« Reply #2 on: September 19, 2023, 08:33:43 AM »
If the output shaft nut has come loose, that could cause it, but it would seem 4th would be also. Possibly a bent or worn shift fork, and/or rounded engagement dogs on the gear and/or sliding sleeve.
Offline siabeid
« Reply #3 on: September 20, 2023, 08:15:24 AM »
Thanks. Looks like I will be pulling the gearbox this winter.
