98 EV regulator replacement
Topic: 98 EV regulator replacement (Read 1428 times)
Dan Beaman
SW Iowa....no we don't grow potatoes here!
October 15, 2023, 01:21:49 PM »
I purchased a new regulator for my EV and its supposed to be the "improved" version with direct-to -battery power. The problem is that I have no clue how to hook it up. Anyone have one like this? I'm assuming the red and green wires on the new are thre power sources. The red has a 20 Amp fuse so it goes to the battery? Does the green then go to the old plug in ?
Here are the pics of the old and new.
I also emailed the company to see if they have a diagram for the modifications in the wiring that need to be done.
Last Edit: October 15, 2023, 03:34:46 PM by Dan Beaman
MGNOC L797
'81 G5
'98 EV
Wayne Orwig
Re: 98 EV regulator replacement
Reply #1 on:
October 16, 2023, 08:48:21 AM »
It looks like ....
Green to ground, and red to battery.
BUT, that alternator can put out over 20 amps. So why would it only have a 20 amp fuse. Something fishy there.
Dan Beaman
Reply #2 on:
October 16, 2023, 02:45:23 PM »
Hmmmmm....
What would be done with the center wire FROM the bike??? That was the original power source. There are 2 wires from the regulator on that one plug.
Here's the company's info on this unit. Perhaps I should reorder with the one that has the same plug-ins.....
https://www.regulatorrectifier.com/products/1994-1999-moto-guzzi-sport-1100-regulator-rectifier-direct?_pos=2&_psq=Moto%20guzzi&_ss=e&_v=1.0
MGNOC L797
'81 G5
'98 EV
guzzisteve
"Just Ride It"
Reply #3 on:
October 16, 2023, 03:23:45 PM »
You can use the power wire not used for the voltage reg as a power source wire. GPS, power plug or heated gear or whatever.
Dan Beaman
Reply #4 on:
October 16, 2023, 03:42:22 PM »
My fuzzy, electrically-challenged brain is beginning to clear! Thanks guys.
MGNOC L797
'81 G5
'98 EV
