Author Topic: 2024 V85 TT merged threadfest  (Read 19823 times)
Offline janguzzi
    • My YouTube Channel (Guzzi Content)
Re: 2024 V85 TT merged threadfest
« Reply #60 on: March 22, 2024, 03:17:15 PM »
The new airbox cover has indeed been improved, but unfortunately it does not fit into the previous E4 and E5 models.
The shape of the back is more protruding - the bevel is not there.
Kind Regards
Jan, Schuby (near the Danish Border), Germany
www.janguzzi.de
-1992-2002: 1000S, 2nd Series
-2002-2004: V11 Le Mans "Grigio Titanium"
-2004-2011: V11 Le Mans "Rosso Corsa" & 2008-2011: 950S
-2018-2021: California Vintage
-2011: Griso 8V & 2023: V85 TT "Giallo Mojave"
Offline Speedfrog
  • Vieux motard que jamais!
« Reply #61 on: March 22, 2024, 04:40:32 PM »
Thanks Jan!
Good info  :thumb:
'04 V11 Café Sport - '14 Griso 8V SE
Offline inditx
« Reply #62 on: March 22, 2024, 06:28:05 PM »
Darn I was hoping it would.
Thanks just the same.
inditx
inditx
This is the day.....
Offline Ed / AF1 Racing
« Reply #63 on: March 25, 2024, 01:15:11 PM »
the EU Strada version catalog posted, so we got to see the cast wheel part #s.
should be a direct swap, after checking one thing.   The front axle changed part #s from previous V85, all E5+ ones (cast and spoked) take this new part #.  New part # is same as V100, and new Stelvio.  Supplier change? spec change?
Forks also changed part #s from previous V85.  Spec change on the E5+?   Be very shocked if the cast wheels cannot change over to other V85 and you just keep using your current axle.  I bet its more of fork to axle change they did on the E5+.
didnt see any part # changes in the rear, wheel plus wheel cover/3 screws should be it
2B009303   Front wheel spindle
 MOTO GUZZI - STELVIO
 Stelvio E5+ ABS 2024 (EMEA)
 Stelvio E5+ ARAS 2024 (EMEA)
 Stelvio E5 ABS 2024 (NAFTA)
 Stelvio E5 ARAS 2024 (NAFTA)
 MOTO GUZZI - V 100
 V100 Mandello Aviazione Navale E5 ABS 2023 (APAC)
 V100 Mandello Aviazione Navale E5 ABS 2023 (EMEA)
 V100 Mandello Aviazione Navale E5 ABS 2023-2024 (NAFTA)
 V100 Mandello E5 ABS 2022-2023 (APAC)
 V100 Mandello E5 ABS 2022-2024 (EMEA)
 V100 Mandello E5 ABS 2023 (NAFTA)
 V100 Mandello S E5 ABS 2022-2023 (APAC)
 V100 Mandello S E5 ABS 2022-2023 (EMEA)
 V100 Mandello S E5 ABS 2023 (NAFTA)
 MOTO GUZZI - V 85 E5+
 V85 TT E5+ 2024 (EMEA)
 V85 TT Strada E5+ 2024 (EMEA)
 V85 TT Travel E5+ 2024 (EMEA)
Offline inditx
« Reply #64 on: March 25, 2024, 01:55:08 PM »
 MOTO GUZZI - V 100
Thanks Ed!
Now to save our pennies up.
inditx
inditx
Offline janguzzi
« Reply #65 on: March 26, 2024, 04:13:03 PM »
Hallo Ed,
will the new, small Strada front fender fit on E4/E5 models?
Kind Regards
www.janguzzi.de
« Reply #66 on: March 27, 2024, 01:03:53 PM »
Hallo Ed,
be very shocked if it didnt fit, all looks like the same mounting
Offline janguzzi
« Reply #67 on: April 05, 2024, 12:57:48 PM »
 :thumb: Thanks Ed!
Do you also have a code number for this?
Unfortunately the new and improved airbox cover does not fit (see above).
Now I am thinking about if it would if replacing 2B005442 too:
... :cool:
Kind Regards
www.janguzzi.de
« Reply #68 on: April 16, 2024, 05:08:17 PM »
the NAFTA (USA/Canada) catalogs got posted.
we just uploaded them, if anyone wants to browse around at the new parts on the E5+ version coming soon.
https://www.af1racing.com/v85-e5-oem-parts-catalogs
« Last Edit: April 17, 2024, 12:08:10 PM by Ed / AF1 Racing »
Offline janguzzi
« Reply #69 on: April 17, 2024, 09:48:38 AM »
Thanks a lot Ed!
These are probably the differences that affect the new airbox lid (12) => part 4 is new and different and part 10 (w. three screws 11) is new. If this would solve the problem with the bad lid, the costs would probably be manageable:
You would need:
1. battery box: 2B011780
2. battery holder: 2B011781 + 3x AP8150509 self-tap screw 5x14
3. filter holder (aka airbox lid): 2B011834
« Last Edit: April 19, 2024, 02:21:10 AM by janguzzi »
Kind Regards
www.janguzzi.de
Offline MattiGuzzi
« Reply #70 on: April 18, 2024, 12:58:34 PM »
Any word on availability date in the US yet?
MM
2003 Moto Guzzi V11
2015 Aprilia Caponord 1200
2020 Moto Guzzi V85TT
2016 R1200GS
Online PeteS
« Reply #71 on: July 13, 2024, 12:45:23 PM »
Just back from a test ride on the new V85. Guzzi is doing demo rides near me. I see one in my future for sure as soon as I can make room for it.
I have not ridden the previous version so can’t do a comparison but power was more than adequate. I had no problem staying with the Stelvio in front of me. Could do without the space age display but otherwise riding position suited me almost perfectly. Brakes are very strong. Main glitch was the notchy gearbox especially in the lower gears. Could not get it into neutral and neither could the Guzzi rep at the end of the ride. About 85F here today and heat was not a real issue. Windscreen didn’t create any buffeting. Other than the gearbox, Guzzi has a winner here.
Offline Clifton
« Reply #72 on: July 13, 2024, 02:49:10 PM »
....Could not get it into neutral and neither could the Guzzi rep at the end of the ride.
Something must be wrong with it then because it should click right in. Of course being a dry clutch if it doesn't (with just the slightest press) they will mesh with ever so slightly releasing the clutch to turn the gears. The V100's are just the opposite in that since the gears are spinning from their wet clutch dragging, two gear teeth can never can line up opposite each other. However there's a loud clunk and slight lurch going to first from the spinning gears coming to a sudden stop.
24 Stelvio
21 V85TT
20 XT250
14 CB1100
08 1200R Sportster
93 R100R
Online PeteS
« Reply #73 on: July 13, 2024, 03:12:12 PM »
I noticed some free play in the clutch cable. If it was mine I would have taken some of that up. Engagement was abrupt but I was able to adjust to that. Only so much you can do on a demo ride. I have to say it was a great ride on some back roads maybe 30 minutes long. Well worth the trip if they come by you.
Online blu guzz
  • Loves to ride
« Reply #74 on: July 13, 2024, 03:13:48 PM »
I went to a breakfast meet up this morning and there were 3 V85s there.  Made me miss mine.  I had one of the first ones in 19 and it was a honey for my whole 4 years with her.
Blue Guzz
Online Trialsman
« Reply #75 on: July 13, 2024, 03:20:40 PM »
Just got back from a ride down south of here.  The gearbox on the V100 Stelvio is getting better but no where as smooth as my V85!  Once the V85 gets broken in, sometimes you cannot even tell you put it in gear other than it moves correctly - no crunch, no lurch, just smooth.  I did notice much more heat was generated today as the temp was in the mid 90s.  The V85 was never this hot to ride.
2010 FE570 Husaberg
2019 Alta Redshift EXR
2021 Moto Guzzi V85TT Centenario
2024 Stelvio V100
2025 Arctic Leopard Ex-800
« Reply #76 on: July 13, 2024, 04:47:46 PM »
I’ve only ever owned 3 Guzzi’s 2 of which I still have. But my experience with both of them (‘07 Norge and V85), is that when you pull the clutch in, if you wait 2 seconds you cannot tell that the gear has engaged, it really is that smooth. I’ve never been on a liquid Guzzi.
Offline Vagrant
« Reply #77 on: July 13, 2024, 04:48:00 PM »
The setting is 2MM and they mean it. If twice that it doesn't go into gear very well. It is one of the best gear boxes of the 50+ bikes I've owned.
The "rep" must not have known S...!
Offline Moparnut72
« Reply #78 on: July 13, 2024, 05:53:45 PM »
The gearbox on my Mandello was just awful when new. I would have to shut off the engine to be able to put it in neutral. Could pull or push as hard as I dared, wouldn't happen. Now at 4,000 miles almost as smooth as my V7. I think whomever machines the shift drums must get a little sloppy after lunch or Friday afternoon. No biggie. My dealer told me all Italian bikes do that.   :violent1:
kk
Mopar or Nocar
2023 V100 Navale
2019 V7lll Special
MGNOC #24053
Offline bad Chad
« Reply #79 on: July 01, 2025, 06:40:27 PM »
The 2025 TT is stunning in the flesh, and it works just as well.
2016 CSC 250TT Zongshen
