Haven't had any issues hitting valve at BDC in over 50yrs so I don't think I'll have one. I'm out, if your an expert like the rest here, you fix it. NO WONDER every tech leaves this place, the TROLL factor is terrible.
Wrenching on these old bikes, sure is a learning experience! I have to keep reminding myself "check the simple things first" If I would have had the presence of mind to do a compression check first, I would have avoided the owner from spending money on the crank sensor, wires, caps, TPS,etc. Live and learn, fellas! Its all good, though. I view it all as part of the learning curve. Once we get the head and cylinder pulled, I will take photos,and follow up with you guys here as to what the findings are. Thanks to every single one of you guys that have helped me. You guys rock! Rick.
You didn’t say do it at BDC, you gave no specifics. Simply put it’s bad advice and you have to consider a newbie reading this and think it’s ok to bang a valve open.I guarantee you the cause would have been long ago solved if the bike was in front of me.If I gave incorrect advice then correct that, I know why you posted what you did and that my friend was trolling.Reread my post I gave advice as to why he could be having an issue with the leak test and gave him things to check, that’s not trolling.You were incorrect in your advice and rather then admit it was a mistake you played the troll card.Not cool.
He said bdc in the first sentence. No edit. It’s the only place to stake a valve safely. it’s useful to blow seat/valve interface in case there is crud there. The advice is correct.
My bad, I do an extreme test at bottom cause it should be tighter(rings). No trolling, I shouldn't be on computer anyway.
In the aircraft shop after a run in on an overhauled radial we did a leak down test. It was always done at top TDC. I don't know why but that's what was done. Those engines don't have a cam as we know them the but used a cam plate. Had to hold on to the prop and it was surprising how much force there was even at only 80psi.kk
I realized the bike has had a sloppage plate of some type installed. You can see the alloy plate between the sump spacer, and the block. almost all the alloy bits on the bike have been powder coated black, etc. You can tell the bike has been taken all apart,and "messed with" alot.Rick.
I guess its possible once the engine is spinning up to speed.
hey Guys, I pulled the head. The cylinder looks good, I believe. The area of the head, around the exhaust valve looks blackened. I turned the head upside down ,and filled it with water, water ran out the exhaust port. no water came out the intake port. You can see the water dribbling out in the second photo.Rick.
Like I mentioned a long time ago.. a proper leak down test would have told you if the rings are bad, too. (shrug) Now, you don't know.. you may just get the head done, put it back together, and find out the rings need to be replaced. (I'm guessing they are ok, though)
Check out the area around the exhaust port in the rocker box. it is all blackened. What do you guys think of that? The area around the intake port looks normal. This is the right side head. The left side is where I originally found the valves had zero clearance.Rick
With a leak at the exhaust valve a leak down test would not help him determine if the rings were worn. To determine if the rings are worn the valves would have to seal. Would work on the good cylinder but not the one reading 30 psi.
You have to be *right at* TDC. Otherwise, pressure will just push the piston down, and you have to start over.I respectfully disagree. I can hear 30 psi. at the breather without an issue.
Make sure that if you disassemble both heads at the same time that you keep track of which valves belong to which head. Common sense I know, but easy to get them mixed up especially on 4v heads , I am still a bit skeptical about the rings , It looks from the bore photo that there is a bit of corrosion ? At this point may be worthwhile to have a look. could have a stuck compression ring
