Author Topic: Tonti rotor removal  (Read 3004 times)
Offline brider
Tonti rotor removal
« on: November 26, 2023, 09:37:59 PM »
Just a quick sanity check: The alternator rotor retaining bolt is a right-hand ("normal"?" thread, right? Like any other righty-tighty lefty-loosy bolt? It's been years since I removed one and I anticipate some heavy torque in a recessed-hex-head bolt to loosen it, so I want to make sure I'm turning the correct way. I'm ALWAYS leery of high-torque hex heads, once you round it off you're screwed. And speaking of rounded-off hex, that's why I'm removing the rotor, to remove the front cover to fix the rounded-off hex on my ATF pump assembly.
'85 Cal II Auto
'71 Ambo project
'02 GasGas EC300
'07 Norge
'05 KTM 950 Adventure
Wish'd I'd never sold:
'72 Red Eldo
'74 White Eldo LAPD
'77 Convert with DB bags
'06 Gas Gas EC300
'86 LM IV
Re: Tonti rotor removal
« Reply #1 on: November 26, 2023, 09:45:00 PM »
Yes, "normal" right-hand thread. Really shouldn't be that tight.
Offline jhem68
« Reply #2 on: November 26, 2023, 10:18:20 PM »
Off the top of my head, I believe the torque spec for that bolt is 14 ft/lbs. And when removing the rotor do not apply any more than the recommended force after inserting the removal tool/pin. If the rotor doesn't come loose at the recommended torque spec then rap the rotor with a soft (rubber or copper or rawhide) mallet and it will pop off. Just be ready to catch it.
Online John A
« Reply #3 on: November 26, 2023, 11:22:52 PM »
Use a hardened pin , if it is regular steel it may deform and lodge in the hole.
Online Tom H
« Reply #4 on: November 27, 2023, 09:48:16 AM »
When using the correct removal tool or suitable substitute and the rotor will not budge. Use a regular hammer and give the head of the removal tool a good rap or two, normally pops right off.
« Reply #5 on: November 27, 2023, 09:55:59 AM »
When using the correct removal tool or suitable substitute and the rotor will not budge. Use a copper hammer and give the head of the removal tool a good rap or two, normally pops right off.
FTFY  :smiley:
Offline bigbikerrick
« Reply #6 on: November 27, 2023, 10:35:42 AM »
Are you replacing the rounded hex pump drive with something improved, as in cutting your own hex  from a tool?  How did it go down, has it been "slipping" for a while, and giving you warning, or was it a sudden backfire/ failure?
Good luck with the repair,
Rick.
Offline brider
« Reply #7 on: November 27, 2023, 11:29:53 AM »
Thanks, all. I had a fuzzy memory of a threaded removal tool I used previously, with (2) different sizes of thread on it's shank, but could not find it after years of not using it. But I DID find a curious straight shaft in a ziplock bag with a seal, and after reading a bit here I realized it's the straight-pin removal tool with a replacement cover seal. How's THAT for luck!
To answer Rick's question: Yes, this is for my Cal 2 Auto slippage, it reared it's head suddenly coming home from work after a 5-day trip a couple of weeks previous that included climbing Mt. Washington in low gear, what I thought was a REAL test of the drive system. Worked flawlessly then. I still jerk awake in a cold sweat dreaming of what might have happened if that hex-drive failed climbing up the mtn.
After that climb, I had (1) single backfiring incident. Couple of weeks later the familiar symptoms appear. Coincidence? Experienced minds here say "no". I failed a hex a number of years before that after a chronic backfiring spell. In this case, it was a higher-than-normal revving during the 6-mile highway run coming home from work, then after the exit ramp stop sign very little hp being transferred to the rear wheel. I limped the 1/2-home. Convert owners who've experienced this know the feeling (physically & mentally).
I would LOVE to re-install an improved hex-drive element, but not sure what the current state-of-the-art is. My last (current) one is a piece of 6mm hex wrench cut to length. I recall Charlie actually mic'ed the cam and pump and had a custom shaft made that closed up some of the slop @ something above 6 mm, so I guess I'll wait to see what the mating elements look like before deciding.
'85 Cal II Auto
'71 Ambo project
'02 GasGas EC300
'07 Norge
'72 Red Eldo
'74 White Eldo LAPD
'06 Gas Gas EC300
'86 LM IV
« Reply #8 on: November 27, 2023, 12:24:47 PM »
I had a piece of 1/4" Bondhus allen wrench surface ground to 6.2 mm. That fit snug into the cam and better into the pump coupling. 30k miles on it so far.
Offline brider
« Reply #9 on: November 27, 2023, 01:04:44 PM »
Just as a point of interest: How do you surface-grind a 6-sided object and take equal amounts off each face? From .25" to 6.2 mm (converting as necessary) is around ~.006" per face. I love the idea, but that ain't much to be able to control it so you don't end up with a lopsided part. Just thinking out loud.....
'85 Cal II Auto
'71 Ambo project
'02 GasGas EC300
'07 Norge
'72 Red Eldo
'74 White Eldo LAPD
'06 Gas Gas EC300
'86 LM IV
« Reply #10 on: November 27, 2023, 01:44:06 PM »
I left the job to a qualified machinist friend, not sure how he did it.
Online ray bear
« Reply #11 on: November 27, 2023, 02:33:37 PM »
In reply to Briders question I have also done the modification that Charlie has done and set the 1/4 hex in a rotary table on the mill and a stone , nice light passes to keep the key from getting hot , you could do it with a dividing head ? Hmm , rotary table was the easiest for me and rotate to required degrees . Ray
« Last Edit: November 27, 2023, 02:36:07 PM by ray bear »
73 V7 sport
73 Eldo police special
68 BSA rocket 3
74 Norton Commando
78 Honda CBX 1000
47 HRD vincent Rapide
XT 500 Yamaha
Offline wirespokes
« Reply #12 on: November 27, 2023, 03:35:19 PM »
I could grind down a hex key in the precision grinder. Chuck it up, grind, rotate 60 degrees, grind again, etc. Easy
Online ray bear
« Reply #13 on: November 27, 2023, 04:53:00 PM »
So long as what ever way you choose has a very accurate control of measurement  as each cut has to be exact to the thou or you end up with an eccentric hex and  only 2 or 3 sides of the key sharing  the load which would accelerate wear . A good table with an accurate  digital read out would be preferred . it certainly is the Achilles heel of the convert and thought by now some of the guys that have tried like road kill may have come up with the perfect solution to that drive.
« Last Edit: November 27, 2023, 04:59:31 PM by ray bear »
73 V7 sport
68 BSA rocket 3
74 Norton Commando
78 Honda CBX 1000
XT 500 Yamaha
Offline Moparnut72
« Reply #14 on: November 28, 2023, 11:39:26 AM »
That was the first thing that came to mind. Our machinist friends here came to my rescue but I am not familiar with those kinds of machines. We had a surface grinder in the shop which was mainly used to grind rings to fit pistons.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
« Reply #15 on: November 28, 2023, 04:20:40 PM »
Pfffft. Just put it on a magnetic chuck on a surface grinder. Easy Peasey..
« Reply #16 on: November 28, 2023, 07:21:12 PM »
I think that might be the way my friend did it.
Offline brider
« Reply #17 on: November 28, 2023, 08:55:17 PM »
Please explain this operation to me like I'm a 4-yr old. The setup, what the chuck looks like, what the surface grinder looks like, how the grind depth is controlled, etc, with pictures (best) or hand-waving if necessary.
'85 Cal II Auto
'71 Ambo project
'02 GasGas EC300
'07 Norge
'72 Red Eldo
'74 White Eldo LAPD
'06 Gas Gas EC300
'86 LM IV
« Reply #18 on: November 28, 2023, 09:50:34 PM »
The video in this auction should answer your questions: https://www.ebay.com/itm/285562109464
« Last Edit: November 28, 2023, 09:55:27 PM by Antietam Classic Cycle »
Online John A
« Reply #19 on: November 28, 2023, 11:07:16 PM »
Wow! I’m in love !
« Reply #20 on: November 29, 2023, 06:11:40 AM »
Mine is even older.. :smiley: I gave $300 for it back in the day.  :rolleyes:
Offline brider
« Reply #21 on: November 29, 2023, 08:18:44 PM »
And it's made in St. Louie! That's where I bought my first & second Guzzis! I love it for it's functionality and American art form.
Maybe I missed it: Is there a way to zero-out net contact with the surface you're grinding, then set the grind depth on a vernier scale on the vertical-grind adjustment? How else could you accurately set the grind depth?
'85 Cal II Auto
'71 Ambo project
'02 GasGas EC300
'07 Norge
'72 Red Eldo
'74 White Eldo LAPD
'06 Gas Gas EC300
'86 LM IV
Online ray bear
« Reply #22 on: November 30, 2023, 02:40:48 AM »
your very correct Brider they havent worked that out yet, you will end up with an eccentric hex which may only be contacting on 2 or 3 sides and will destroy a very hard to get pump drive and camshaft prematurely  . you must zero and be able to cut within thousands of an inch and each side of the hex must be identical ,I have a convert and have performed that modification do it right :popcorn: :popcorn: :popcorn:
« Last Edit: November 30, 2023, 03:05:00 AM by ray bear »
73 V7 sport
68 BSA rocket 3
74 Norton Commando
78 Honda CBX 1000
XT 500 Yamaha
« Reply #23 on: November 30, 2023, 01:23:07 PM »
Grinding machines in general are *very* accurate. Even my antique surface grinder's feed wheels are graduated in half thousandths. Instead of sloppily plunging into the workpiece like the guy showed on the video  :shocked:  :rolleyes: you slowly kiss the surface. From that point you can easily take off .006", turn one flat,cut, turn, then feed down another .006" to do the other 3 sides.
Offline Moparnut72
« Reply #24 on: November 30, 2023, 04:09:34 PM »
The surface grinder we had would feed by itself. The do all the rings for a 7 cylinder radial would take a good part of the day. It hardly took anything off on each pass.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
