Author Topic: V7III rear blinker Bulbs  (Read 2963 times)
Offline 9fingers
« on: December 05, 2023, 08:41:21 AM »
Hi all, at 17,203 miles I had my first break down.......a turn signal bulb burned out. No biggie I figure, just get one from AF1 racing. They say 1 ordered to day will arrive in May....really? And their website and the parts manual I have copied shows it as a clear 5w bulb. So I removed it and took a pic of the tiny numbers on the bulb and found out, of course, that it is amber and 10w! What's up with that? Solution was Amazon. Link below if anyone needs a tail light bulb. Should be here Thursday, which is good, as Friday is supposedly partly sunny and a high of 49, so taking the day off for a ride.
Regards,
https://www.amazon.com/dp/B07YK5M9CQ?ref_=pe_386300_442618370_TE_sc_as_ri_0#customerReviews
« Last Edit: December 05, 2023, 09:34:40 PM by 9fingers »
Current bikes:
V7 Corsa - Athena
Suzuki V Strom 650 - Rita
Beta Rev 3 270
Honda TLR200 custom
Honda TL250 custom
TL250 stock
Honda TL125
Yamaha TY350
Offline Kev m
Re: V7III Tail Light Bulbs
« Reply #1 on: December 05, 2023, 09:19:09 AM »
I put an inexpensive Sylvania LED bulb in both my MKI and MKIII housings. I liked the performance (bright, fast illumination) but the one in the MKI burnt out in not much more than a year - I put the old incandescent (probably the original) bulb back in.
Guess I should buy a spare or two. Might try another LED solution.
Offline Moparnut72
« Reply #2 on: December 05, 2023, 11:08:45 AM »
The tail light bulb in my V7lll Special gave up the ghost at about 3,500 miles. I just replaced it with a normal bulb, I don't remember the number but I think it was an 1157. The manual called for some oddball wattage so I went with the 1157. I also carry a spare around with me if normal life expectancy is so short due to vibration, from the road not the engine, of course.  :thumb:
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
« Reply #3 on: December 05, 2023, 01:05:20 PM »
I just popped an LED replacement bulb in mine when it went.  Can't even say how many years it has been hanging on the pegboard.  At least 10 I'm sure of.
I already had Skenedesign LED Run/Turn/Brake lights on either side of my license plate so didn't really need to replace the bulb so I thought, might as well try the LED bulb.
« Reply #4 on: December 05, 2023, 01:07:05 PM »
Hi all, at 17,203 miles I had my first break down.......a tail light bulb burned out. No biggie I figure, just get one from AF1 racing. They say 1 ordered to day will arrive in May....really? And their website and the parts manual I have copied shows it as a clear 5w bulb. So I removed it and took a pic of the tiny numbers on the bulb and found out, of course, that it is amber and 10w! What's up with that? Solution was Amazon. Link below if anyone needs a tail light bulb. Should be here Thursday, which is good, as Friday is supposedly partly sunny and a high of 49, so taking the day off for a ride.
Regards,
Your link went to turn signal bulbs, not tail light bulbs.   :shocked:
Offline 9fingers
« Reply #5 on: December 05, 2023, 05:17:33 PM »
That is because I am an idiot. I MEANT turn signal bulb...........than ks for pointing that out.
Current bikes:
V7 Corsa - Athena
Beta Rev 3 270
Honda TLR200 custom
Honda TL250 custom
TL250 stock
Honda TL125
Yamaha TY350
Offline Kev m
Re: V7III rear blinker Bulbs
« Reply #6 on: December 06, 2023, 05:56:06 AM »
Ha ha, oh yeah that (turn signal bulb) was different. IIRC I went to 2-3 auto parts stores, like Napa, AutoZone, and Advance and none of them carried the right replacement. I too wound up buying online, I think it was Amazon.
« Last Edit: December 06, 2023, 05:56:36 AM by Kev m »
Offline elrealistico
« Reply #7 on: December 06, 2023, 06:37:39 AM »
Same as some other folks, I had a twofer of 1157 base LED bulbs I got, put one in the Triumph--it got shook apart after awhile, went back to incandescent--and stuck the other in the III, the bulb was still good, figured why not upgrade the tail light whilst changing the headlight bulb to LED? Both are still fine 3000 miles or so later
2018 V7III Special
1978 T140V Bonneville
2004 EV Touring
Online Dr. Enzo Toma
« Reply #8 on: December 07, 2023, 01:03:17 PM »
What a catastrophe!  :tongue: Are you the original owner? Wonder if the bulb had already been changed at some point.
One of the first changes I made to my USA 2022 V7 850 e5 was installing the OEM Euro LED turn signals on it, purchased through AF1 Racing. Very happy with them, especially their appearance.
MGNOC Member
Offline jrt
« Reply #9 on: December 08, 2023, 08:27:40 AM »
This is a good reminder to check your blinker fluid on occasion. I like to run synthetic, but I know others prefer organic.
L-720
1973 Eldorado
2003 Yardbird (1100 hydro)
2020 R1250RS
Offline 9fingers
« Reply #10 on: December 09, 2023, 11:37:52 AM »
THEY DON'T FIT! The bulb base is correct but the engagement nubs are mounted at 180 degrees, not like the slots on the V7 directional, which is perhaps 165 degrees........for some reason.
Not pleased.
Scott
Current bikes:
V7 Corsa - Athena
Beta Rev 3 270
Honda TLR200 custom
Honda TL250 custom
TL250 stock
Honda TL125
Yamaha TY350
Offline 9fingers
« Reply #11 on: December 27, 2023, 09:11:12 AM »
Update, finally got 2 blinker/directional bulbs from www.Scooterwest.com, for $24 shipped.
Current bikes:
V7 Corsa - Athena
Beta Rev 3 270
Honda TLR200 custom
Honda TL250 custom
TL250 stock
Honda TL125
Yamaha TY350
