Author Topic: mild head work advise  (Read 2081 times)
Offline spmoto
« on: December 08, 2023, 01:35:24 PM »
I would like to have the heads on my G5 massaged a bit. I'd like to open up and flowed for 36mm carbs, valves and guides etc. I haven't had a need for this kind of work since Manfred Hect of Raceco fame passed. Any recommendations? Thanks,
Steve
Re: mild head work advise
« Reply #1 on: December 08, 2023, 04:24:04 PM »
I know Ace Malott has a flow bench and does head work. MGNOC past MO rep.
Offline spmoto
« Reply #2 on: December 08, 2023, 04:30:22 PM »
Thanks Sreve
Offline Turin
« Reply #3 on: December 08, 2023, 08:45:04 PM »
Any engine mods? if not you could just blend the intake port to the manifold with a dremel.
1985 Sidlow Guzzi
Offline johnwesley
« Reply #4 on: December 10, 2023, 08:49:19 AM »
Ace did the heads on Dad’s 1100 guzzi and it runs well.
Arkansas MGNOC rep
2003 cal ev custom build/ adv scrambler thing
2000 Quota
1989 cal III FF
1985 cal II
1977 T3 California
Offline Turin
« Reply #5 on: December 10, 2023, 02:15:08 PM »
here is the job my buddy Tom Hull did on my 850T heads. Thinner copper head gaskets were used.
1985 Sidlow Guzzi
Offline spmoto
« Reply #6 on: December 10, 2023, 02:43:35 PM »
Thanks Turin. So, I assume you stayed with the small valves? What size carbs did you use, 36's? Years ago I met Tom, very briefly. Some time in the late 80's my wife and I did a fly and ride to Buy a Cal II from Dave. We had a great experience and ended up going back a couple more times. It was the same weekend in May as the Arizona MGNOC rally which used to be the kick-off rally of the year.
Steve
Offline Turin
« Reply #7 on: December 10, 2023, 06:43:39 PM »
Cool! Dave is the one who turned me onto Guzzi's when I was in high school! The Best! They sold the shop in 1997. I bought Dave's old race bike in peices.
 I'm at Tom's house about once a week.
here is a video of a joyride with Tom.
https://www.youtube.com/watch?v=oW000KavtVI&t=8s
He ported the heads himself and we installed stock sized stainless steel valves. It runs a Norris S / megacycle X9 cam and 36mm delortos. Mistral exhaust with conti rep mufflers. Compression was bumped / squish set at .040 with thinner copper head and base gaskets.
The T it pulls harder down low than my lemans 3.
1985 Sidlow Guzzi
