Author Topic: V7-850 service part numbers  (Read 2234 times)
Offline SportsterDoc
« on: December 09, 2023, 11:40:25 AM »
I did a lot of research before purchasing my final M/C
It was a very good decision.
Triumph of Albuquerque, now Motopia, started representing Moto Guzzi at just the right time.
My V7-850 was the first MG they sold.
Riding on the street since March 1963 has wonderful memories and  a few stories for grandkids/great-grandkids...
but that time is drawing to a close.
Just under 5400 very enjoyable miles since 5 May 2023
So, trying to think of what I might share with fellow V7-850 riders, here are factory part numbers for common service items:
spark plugs (0.032 gap)                    NGK MR8B1-8  (91360)
oil fill o-ring                                       A014908
oil filter                                              2A000633
filter o ring                                        GU90706444
filter crush                                        GU12154200 (8.25 mm ID)
oil drain washer                               GU01528930 (10mm ID)
gearbox plug fill & trans fill o-ring     GU90706203
gearbox drain o-ring                       1A016739
trans drain M12 washer                   224566
air filter                                             AP8104924
« Last Edit: December 12, 2023, 11:00:01 AM by SportsterDoc »
23 V7-850 23 Yam XT250 18 Yam Bolt  22 Triumph St Twin  20 CanAm Ryker 14 Honda CB1100 18 Yam XT250 16 MG V7II 17 Yam TW200 12 Triumph Bonnie 02 Sportster 1200S 03 Sportster XLH883 76 Honda 750F 75 Honda CB360 70 Yam CT1 72 Yam CT2 72 Yam AT2 70 Honda SL350 70 Honda CL350 67 Honda CL160 67 Honda C11
Re: V7-850 service part numbers
« Reply #1 on: December 12, 2023, 11:37:42 AM »
And 2023 V7-850 Special Edition now listed for sale
https://wildguzzi.com/forum/index.php?topic=120066.msg1872477#new
Sorry to hear - but best of luck with future endeavors.
« Reply #2 on: December 12, 2023, 12:58:17 PM »
Thank you, Kevin
If it does not sell here or on the CB1100forum, then Motopia will purchase in the spring.
May put the $ towards a tractor for my son's farm
It is only 3.5 acres, so a small one is likely
A local  friend has a 1948 Ford 8N
The V7-850 is a great way to end 60+ years of riding!!
