Author Topic: Help me identify this sound.  (Read 1407 times)
Offline Dino172
« on: December 11, 2023, 12:05:25 PM »
https://www.dropbox.com/scl/fi/7q0a8q378oby1is2frb3v/IMG_0180.MOV?rlkey=1bywn4bmuuql0lgds2cl6r7ry&dl=0
This sound I'm trying to track down under load. I adjusted valves but did nothing. I am now leaning towards clutch or gearbox thrust bearing. Any help is appreciated.
Between 13min-15 min metal tapping rattle sound.
« Last Edit: December 11, 2023, 12:20:43 PM by Dino172 »
17 V7 III Stone
Offline Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
Re: Help me identify this sound.
« Reply #1 on: December 11, 2023, 12:28:00 PM »
Is it on one side more than the other?
Check the exhaust nuts?
Have you used a stethoscope to try and locate the source?
Offline Dino172
« Reply #2 on: December 11, 2023, 12:35:18 PM »
No I can hear from both sides of the fuel tank if I put hy head down.
Exhaust nuts are tight are torqued with nord lock washer.
Can't do that because the sound only appears under load. ( it does not sound like pinging or detention or lugging.)
17 V7 III Stone
« Reply #3 on: December 11, 2023, 12:48:20 PM »
Hmmm…
My backyard dyno would be handy.
« Reply #4 on: December 11, 2023, 01:02:01 PM »
Yeah I can definitely hear it.
I don’t know…Yet.
Nothing loose around the throttle body or butterfly ?
Offline Dino172
« Reply #5 on: December 11, 2023, 01:05:00 PM »
I don’t know…Yet.
Not that I can see. I have heavy-duty zip ties on it.
17 V7 III Stone
Offline lucian
« Reply #6 on: December 12, 2023, 09:08:23 AM »
chasing noises can be a pain . I always start by winding up to speed on a vacant road and then shutting the engine off and coasting in neutral to  isolate chassis noises form engine / driveline noises
Offline slowmover
« Reply #7 on: December 14, 2023, 09:24:26 AM »
I had a noise was driving me nuts until I tracked it down to a loose piece in the headlight housing.
Online elrealistico
« Reply #8 on: December 16, 2023, 11:52:25 AM »
I used to worry about annoying noises, but I don't have a wife anymore  :thewife:
2018 V7III Special
1978 T140V Bonneville
2004 EV Touring
Online cliffrod
« Reply #9 on: December 16, 2023, 12:27:50 PM »
I started losing my hearing instead.  Now my wife has to tell me about annoying noises that I can’t hear….
Carolina Sculpture Studio YouTube Channel-
« Reply #10 on: December 16, 2023, 12:30:08 PM »
She must be happy now…
Online normzone
« Reply #11 on: December 17, 2023, 12:04:22 AM »
Sounds like something flapping against your phone while you record a Moto Guzzi. Either that or something loose flapping on said Guzzi.
