Author Topic: Suggested maintenance when changing tires  (Read 2753 times)
Offline Moda253
« on: February 13, 2024, 09:00:41 AM »
On the Jackal, specifically regarding the rear wheel, what maintenance items should be performed while the wheel is off the bike?
I need to replace the tires this upcoming week and want to make sure I have all the items I need to do any other work that males sense to do.
2000 California Jackal (Currently under restoration)
Re: Suggested maintenance when changing tires
« Reply #1 on: February 13, 2024, 09:07:01 AM »
Change the rear drive oil, grease the splines.
« Reply #2 on: February 13, 2024, 09:49:42 AM »
What Charlie said as well as inspect the wheel bearings. No need to remove them, just give them a turn and see how they feel. Check the seal in the rear drive for leaks.
Offline Moda253
« Reply #3 on: February 13, 2024, 10:14:05 AM »
Yep Iw ill be doing the rear drive lube change.
Any recommendations for spline grease? And do I just smear it on them?
Offline jrt
« Reply #4 on: February 13, 2024, 10:19:48 AM »
Have a look at your brake pads.
L-720
1973 Eldorado
2003 Yardbird (1100 hydro)
2020 R1250RS
« Reply #5 on: February 13, 2024, 10:37:33 AM »
I like Wurth SIG 3000: https://www.mgcycle.com/index.php?main_page=product_info&cPath=23&products_id=1914
I've found it really likes to be applied to a clean and dry surface - no other grease. I apply it with an old toothbrush.
Offline n3303j
  • Ron Cichowski
« Reply #6 on: February 13, 2024, 11:00:47 AM »
Beyond inspecting the pads I drive the pads (pucks) back fully into the caliper then suck out the M/C reservoirs with a 60 cc syringe (found at feed & grain store).
Then I replenish the reservoirs with new fluid and cycle the system until the pads are back on the disks with fresh fluid. Give the system a bit of a bleed. Finally top up the master cylinders and seal the system. Set for another year.
While you are at it might as well check to see that floating disks are actually floating. If not spin, clean or remove the buttons as necessary to get the rotors back to floating condition.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline bigbikerrick
« Reply #7 on: February 13, 2024, 11:14:24 AM »
You may also want to check out and clean the rear wheel  cush drive rubbers,and plate, to make sure it is free,and working as it should.
Rick.
« Reply #8 on: February 13, 2024, 12:32:49 PM »
A good time to check underside of the fender for rubs and wire harness for security.
Online Perazzimx14
« Reply #9 on: February 13, 2024, 12:57:19 PM »
If the tires are tubeless, it's a good time to install new valve stems.
« Reply #10 on: February 13, 2024, 12:58:44 PM »
I like the brake pad cycle.
Gotta’ be mindful not to overflow the master cylinder though.
Offline Moda253
« Reply #11 on: February 13, 2024, 03:19:29 PM »
I just redid the entire wiring with new tail light and turn signals as whatever it was that MG made the original parts from started disintegrating a few years ago.
Offline jrt
« Reply #12 on: February 13, 2024, 03:26:58 PM »
This is glorious- reminds me a bit of the 'stone soup' story.  A little this...and this...and don't forget to add that...  :thumb:
L-720
1973 Eldorado
2020 R1250RS
Offline Scout63
« Reply #13 on: February 13, 2024, 05:15:22 PM »
You could check the swingarm pivots while the wheel is off…
Ben Zehnder - Orleans, MA USA
Offline Texas Turnip
« Reply #14 on: February 14, 2024, 06:15:39 AM »
This is the first time in 40 plus years of Guzzi ownership that I've heard f replacing the valve stems. Please explain why to educate me. TIA
Tex
Online guzziart
« Reply #15 on: February 14, 2024, 07:25:05 AM »
Well, I thought Moda253 indicated he was replacing tires so......replace valve stems if the tires are tubeless.
