Author Topic: Hard Starting 1400  (Read 2051 times)
Offline et18
Hard Starting 1400
« on: May 20, 2024, 07:20:35 PM »
I'm hoping to get some guidance from you guys on what may be causing my starting problem.  The bike is a 2014 California Touring 1400 with about 38K on it.  Always garaged but also ran in all kinds of weather.  Just yesterday it developed a problem when starting where the starter would engage every time for about a second and then stop.  It would do this for 5 or 10 tries, then engage and run perfectly.  It has done this for a while but only one time every once in a while, never several times in a row.  I found a post from SmithSwede describing the exact same symptom on a V7 that turned out to be the phase sensor but the difference is my bike will eventually start and run like a top, this post is located here:
https://wildguzzi.com/forum/index.php?topic=88152.0
I've noticed the starter winds down like a 60's Dodge starter after disengaging, I'm fairly certain this is a new thing.  I think it used to just stop like modern starters but I can't be 100% sure because the engine noise would drown it out if it starts.  But I often have to give it a few tries when warm and I don't remember this sound.
I've confirmed the battery is good and cleaned the ground connection, the battery terminals and connectors and the spade connector on the starter.  The bike started right up when moving it to the garage to check things out but went back to the described problem after removing the starter and cleaning connections.  The starter had a small amount of rust on the housing but otherwise looked OK.
All of the above leads me to believe it is probably the starter but I'm open to suggestions.
One last thing is I was surprised by the amount of oil on the components under the plastic covers, but thankfully not on the cylinders.  I've never been really low on oil between changes and these covers have never been off this 10 yr old bike so probably a slow leak on one of the hoses, just guessing.  There is oil on top of the phase sensor but no more than anywhere else.
1994 BMW R1100RS
2001 BMW R1200C
Offline Stretch
Re: Hard Starting 1400
« Reply #1 on: May 21, 2024, 05:35:37 AM »
Symptomatic of a starter on it's way out, but 38K seems kinda early for that malady.
                                                            -Stretch
1967? Change Jiang M1M
1978 Yamaha SR500
1971 BMW R75/5
1987 BMW K75S
2011 Kawasaki KLR650
2015 Triumph Trophy
« Reply #2 on: May 21, 2024, 07:43:54 AM »
Anyone close by that could run a diagnostic check? Notice anything on dash?
Look at where starter is made, if China it may need a rebuild or replace. They are reliable till they are not.
« Last Edit: May 21, 2024, 04:39:23 PM by guzzisteve »
Offline et18
« Reply #3 on: May 21, 2024, 09:15:27 PM »
Thanks, guys. Starter was made in China, I’ll see who has a replacement in stock tomorrow. Nothing abnormal on the dash, just the whirring sound as the starter winds down after disengaging. I haven’t heard a starter do that since I sold my ‘69 Dodge Coronet about 40 yrs ago.
1994 BMW R1100RS
2001 BMW R1200C
Online blu guzz
  • Loves to ride
« Reply #4 on: May 22, 2024, 06:41:59 AM »
Maybe try one from a 50 year old Dodge? LOL
Blue Guzz
Online Moparnut72
« Reply #5 on: May 23, 2024, 09:25:02 AM »
Mopar starters were much maligned back in the day. Actually they were very advanced at that time with the gear reduction components. Today I think all starters are built that way but the weird sounds have been eliminated.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
