Author Topic: time has come  (Read 3577 times)
Offline Alfetta
time has come
« on: June 10, 2024, 11:30:54 AM »
So the V7(3) (2018) has 16K miles under she belt. and now the check engine light has decided to turn on...
Friday was hot here and the bike was in the sun all day.
I fired it up to and it stumbled and died. (check engine light turned on)
I tried on more time with the same result.
So third push on the start button i gave it a blip of fuel to keep things spinning, It still stumbled, gave me a lean pop. and then slow settled down and ran correctly.
The bike ran just fine for the 20 mile journey home.  And ran fine back to work this morning. (light still on)
So i think its time to get the necessary equipment to run diagnostic test.
Q1.  Will a standard auto OBDII reader work with correct interconnect cable ?
Q2.  Would GuzziDialog software and cabling be a better option ?
« Last Edit: June 10, 2024, 11:31:44 AM by Alfetta »
Offline faffi
Re: time has come
« Reply #1 on: June 10, 2024, 12:37:19 PM »
I cannot answer your questions, unfortunately, but have you checked battery voltage unladen and when cranking? Low voltage can cause all sorts of issues.
Current bikes:
2018 V9 Roamer
1982 XV750/1100 mongrel
1990 XT600Z
2001 NT650V in bits
Offline Xander
  • Riding is my meditation. ATGATT is my mantra.
Re: time has come
« Reply #2 on: June 10, 2024, 01:17:08 PM »
I'm not sure about the V7, but I learned that the V85TT just began compatibility with OBDII in 2021 (or '20?) with the E5 (Euro) standard.  I guess that probably applies to Moto Guzzi in general.   :sad:
EDIT:  I think the prior system on MG bikes requires a proprietary scanner.
I've gotten an adapter (Amazon ~$8) for my ODBII scanner (16 pins) to the plug on my '21 V85TT (6 pins).  I haven't tried it yet, but I'll do so and report back here if anyone's interested.
Very true.  I'm told that on the V85TT low voltage can be a cause of the "startus interuptus" issue which flashes a red warning about the security key instead of starting the brum brum.  I had that issue and charging the battery fixed it.  I've since replaced the battery after testing the charge voltage while running, and I've not had the problem since.
« Last Edit: June 10, 2024, 01:29:23 PM by Xander »
2021 V85 TT Centenario E5
Offline azccj
Re: time has come
« Reply #3 on: June 10, 2024, 07:05:21 PM »
I have the OBD adapter that plugs into my V85tt's red diagnostic plug, and have connected a cheap wireless OBD scan tool into the adapter. It appears to work fine showing fault codes and sensor readings. Also works on my girlfriend's Vespa which uses the same red diagnostic plug.
2023 V100 Mandello S
2007 Norge
2003 V11 Le Mans
2000 Jackel
99 EV
Offline Xander
Re: time has come
« Reply #4 on: June 10, 2024, 07:53:31 PM »
What year is your V85TT and her Vespa?
Offline azccj
Re: time has come
« Reply #5 on: June 10, 2024, 10:21:28 PM »
Both are 2022 models
2007 Norge
2003 V11 Le Mans
2000 Jackel
99 EV
Offline Dr. Enzo Toma
Re: time has come
« Reply #6 on: June 10, 2024, 11:40:46 PM »
2022 models are Euro5 and have the ISO 19689 6-pin diagnostic plug. OP's 2018 model would be different. Remove the seat to identify the plug, it likely has 3 wires.
MGNOC Member
Re: time has come
« Reply #7 on: June 10, 2024, 11:52:44 PM »
My scanner says it should be this plug for the V7 III.
MGNOC Member
Offline Vagrant
Re: time has come
« Reply #8 on: June 11, 2024, 08:08:17 AM »
Odds are the fuel tank over pressurized it and choked it with gas. Next time open the cap and relieve it first.
Guzzling will work and it will let you turn off the O2 sensors that I bet is your CEL problem.
Offline Alfetta
Re: time has come
« Reply #9 on: June 11, 2024, 08:12:37 AM »
Guzzling ??  is that some kind of little goose tuner ??
PS  (2018 OBD is a small three wire plug.)
Offline Vagrant
Re: time has come
« Reply #10 on: June 11, 2024, 08:15:02 AM »
Spell check! Guzzi Dia
Offline Moparnut72
Re: time has come
« Reply #11 on: June 11, 2024, 08:49:18 AM »
My V7lll will do this if the tank is full or near full and has been parked in the sun. There is a cure but it has done it so seldom and is not that big an issue so I haven't bothered to address it.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline bronzestar1
Re: time has come
« Reply #12 on: June 11, 2024, 12:35:59 PM »
That would be my first guess.  I keep my bikes in a storage unit, and since I don't ride them frequently, I tend to keep them topped off when I park them.  When the temps are hot here, I'll crack the gas cap open to let it vent for a few seconds before starting.  Whenever I've done this, there's always been that "psshhh" sound of it depressurizing.  The warmer the weather, the louder and more forceful the sound.
Online Bulldog9
Re: time has come
« Reply #13 on: June 12, 2024, 05:28:00 PM »
Your best bet is to go to Griso.org and follow the link there for the Lonetech cables and adapter, read the info and download the correct programs. There is the GD base program, plus a 'reader' to dowload and 'writer' to upload maps to/from your PC.
The Lonetech cables are Proven and work the first time. People who try to patch and match always have issues.
I bet sitting in the sun, your tank had a ton of pressure build up. GD is a great tool with many functions and tests.
MGNOC#23231
