Author Topic: V50 - new gearbox breather, now won't shift  (Read 3260 times)
Offline jamesfjamesf
« on: June 12, 2024, 12:54:19 PM »
I really thought I was done asking questions now that the bike is all assembled, but when I attempted to roll the bike off the workstand using the clutch as a brake while in gear, I discovered it wouldn't shift into gear. Not up nor down. The lever and linkage move, and there is upwards and downwards spring pressure, i.e. it returns to center, it just won't shift into gear. Something is hitting something becasue there is a metallic clack seemingly from the gearbox, the linkage isn't causing it. It's very much like the gears aren't spinning and allowing the dogs to engage, but neither a running engine nor rolling the bike changes anything.
I replaced the stock breather with the recommended banjo bolt and a banjo fitting:
https://www.thisoldtractor.com/moto_guzzi_small_blocks_transmission_breather.html
I didn't move anything during the swap. It's the only thing I touched on the gearbox, other than separating it from the engine. I'm at a loss. Could the breather swap be doing this or is it a red herring?
thanks,
jim
Online n3303j
  • Ron Cichowski
Re: V50 - new gearbox breather, now won't shift
« Reply #1 on: June 12, 2024, 03:46:51 PM »
Take out the breather bolt and see if everything works. Stuff is close to the case in some parts of the transmission. The replacememt breather bolt probably tangled with something moveable.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
« Reply #2 on: June 12, 2024, 04:49:45 PM »
thanks,
jim
You didn't lose the (detent plunger) spring did you? That could cause it.
« Reply #3 on: June 12, 2024, 09:01:55 PM »
No, I clearly remember having a very hard time compressing the spring long enough to get the threads started. But how would that cause the shift drum not to rotate? I'd assume the shift drum would rotate quite freely without the spring & plunger to index it.
jim
« Reply #4 on: June 12, 2024, 09:31:53 PM »
jim
Just throwing it out there.
« Reply #5 on: June 13, 2024, 10:29:40 AM »
Ok, I thought maybe I was misunderstanding the function of the spring & plunger. Anyway, turns out the new bolt I received is significantly longer than the breather that came out. I thought I measured it before installing. Backing it off a buncha turns fixed the issue so I need to trim the bolt. Stay off drugs, kids.
jim
Online Chuck in Indiana
« Reply #6 on: June 13, 2024, 07:09:23 PM »
Failing memory, thinks you dodged a bullet. That detent locates (from memory again) a bearing? Lose that location, and you're in a heap of trouble, boy.  :smiley:
« Reply #7 on: June 13, 2024, 07:29:40 PM »
You're thinking of the oil pressure sender, Chuck. That locates a cam bearing.
« Reply #8 on: June 14, 2024, 09:56:36 AM »
Quote from: Antietam Classic Cycle link=topic=121269.m :smiley: :violent1: :smiley: :smiley: :lipsrsealed:sg1884143#msg1884143 date=1718324980
Ahh, right as usual, Charlie.  :thumb: It's been several years since I have actually *worked* on a small block, and I'm old. :)
