Author Topic: Burpin the 1400?  (Read 1471 times)
Online inditx
Burpin the 1400?
« on: June 29, 2024, 09:50:33 AM »
Anyone experience having to burp the gas tank on the 1400?
It squeals and hisses until I release the pressure off of it after a ride.
It has been hot here so that may add to it.
Come to think of it, I had a V9 that did this as well.
Anyone else?
Remedies?
Thanks,
inditx
inditx
This is the day.....
Online Vagrant
Re: Burpin the 1400?
« Reply #1 on: June 29, 2024, 10:46:10 AM »
It just means the vent is working.
« Reply #2 on: June 29, 2024, 12:05:21 PM »
Remedy is to delete the EVAP system and tip over valve. If you go over it will leak fuel. But no more moaning.
Online inditx
« Reply #3 on: June 29, 2024, 01:43:20 PM »
How much is involved in that?
Need mapping or other adjustments afterward?
Need to change anything else?
inditx
inditx
Offline ff73148
« Reply #4 on: June 29, 2024, 03:05:15 PM »
Whale moan.
Just open the gas cap.
Frank Ferrante
2024 BMW R12
2022 Can Am Spyder RT Limited
Online TN Mark
« Reply #5 on: June 29, 2024, 03:09:58 PM »
It’s most likely the vent line from the tank is obstructed. The tank should never build up pressure or creat a vacuum. Having to open the gas cap to burp it proves there’s a kink in the line or an obstruction. Possibly by a faulty one way valve.
« Last Edit: June 29, 2024, 03:24:17 PM by TN Mark »
« Reply #6 on: June 29, 2024, 03:17:36 PM »
inditx
Take off tank & follow hoses, look in book. Do a search, plenty of info, been covered. I know it's on the GT forum, canister delete.
Don't have to do much, just take off charcoal canister & reroute hoses. No mapping, nothing.
You have to take 'T' out of the intake hose, replace w/strait or hose connecting both or capped.
« Last Edit: June 29, 2024, 04:57:38 PM by guzzisteve »
Online blu guzz
  • Loves to ride
« Reply #7 on: June 29, 2024, 06:22:30 PM »
It's just the goose honking.
Blue Guzz
