Author Topic: V85TT ecu remapping  (Read 17214 times)
Offline JStorm
Re: V85TT ecu remapping
« Reply #30 on: May 19, 2025, 05:35:25 PM »
I'm still unable to get the front up and over a log. Still have a substantial flatspot between 2800-3000 where it begins to make smooth power.
Frustrating as even after another revision to truly disable the lambda sensors, I get codes if they are not plugged in. I will try again and maybe fully explain my intended uses with the bike being used for more off road stuff requiring usable torque down low.
Update,
I just installed the new mapping from Beetlemaps, did a quick test drive and happy with result.
Just as Mark promised, no real power gains but quit a bit more torque in the lower and mid-range.
Finally able to pull a wheelie   :grin:
