Author Topic: V7iii USB socket  (Read 2787 times)
Offline zip50
  • 2018 V7 III Carbon Shine
    • Title
V7iii USB socket
« on: July 20, 2024, 09:12:55 AM »
I am adding a USB adapter to my V7 III. Found the connector that attaches to the plug next to the battery on Amazon (Link below) and have an adaptor. Just checking that the plug under the seat is fused. Anyone able to confirm?
Edit:  here is the correct one: https://www.amazon.com/dp/B07QGZYXDR/ref=sspa_dk_detail_1?psc=1&pd_rd_w=X7C90&content-id=amzn1.sym.386c274b-4bfe-4421-9052-a1a56db557ab&pf_rd_p=386c274b-4bfe-4421-9052-a1a56db557ab&pf_rd_r=TY8NZ1AB173JF836DT45&pd_rd_wg=qBpqg&pd_rd_r=aa053845-8ab0-4ee7-8ad1-5c17c62dfdbb&s=industrial&sp_csd=d2lkZ2V0TmFtZT1zcF9kZXRhaWxfdGhlbWF0aWM
« Last Edit: July 20, 2024, 12:36:58 PM by zip50 »
Online elrealistico
Re: V7iii USB socket
« Reply #1 on: July 20, 2024, 10:07:11 AM »
That looks like the one for connecting to the ECU. I bought one that connects to the battery and is fused and ran up to handlebars.Clamp came with it, also has 2 USB ports, on/off and LED voltage display. Was like 10-12 USD I think
2018 V7III Special
1978 T140V Bonneville
2004 EV Touring
« Reply #2 on: July 20, 2024, 10:42:50 AM »
I have an SAE battery tender connection so I just bought an extension and USB adapter to use with it.
Offline zip50
    • Title
« Reply #3 on: July 20, 2024, 11:56:47 AM »
Yup, just figured that out. Thanks. Looks like wiring direct to battery with in-line fuse gets me there.
Offline zip50
    • Title
« Reply #4 on: July 20, 2024, 12:40:37 PM »
Since confirmed it is fused. So if you want the ignition to turn it off, connect to the connector next to your battery/under the seat (model dependent). If you want constant power wire it directly to the battery, but be forewarned that a device left on could drain battery power. To search for the connector on amazon/google put in "2 pin superseal amp female connector",
« Last Edit: July 20, 2024, 12:42:19 PM by zip50 »
