Author Topic: Heat and smell from 2013 V7  (Read 4361 times)
Online cmgies
« on: August 04, 2024, 02:32:01 PM »
I was riding to the Oregon Vintage Motorcycles picnic and some guy pulled up to me on his motorcycle and said he could feel heat and smell something hot coming off of my V7. I was almost there so I went on and after I parked I look and smelled around and couldn't figure out what it could be.
Thoughts?
« Last Edit: August 04, 2024, 02:32:32 PM by cmgies »
Michael Gies
'73 R75/5 (sold it)
'07 Norge (sold it)
'13 V7 Special
Re: Heat and smell from 2013 V7
« Reply #1 on: August 04, 2024, 05:19:56 PM »
How the F would someone on another motorcycle feel the heat from yours? Especially if you weren't feeling it?!?
Sounds like a moron.
« Reply #2 on: August 04, 2024, 06:22:33 PM »
Some jealous guy wish he could have bought one! Was he on a BMW?
Offline Bulldog9
« Reply #3 on: August 05, 2024, 12:55:56 AM »
I'm with Kev... $10 says he is on another forum right now telling the stories of how he loves to pull up on other riders (of course NOT from his brand) and say that
MGNOC#23231
Online elrealistico
« Reply #4 on: August 05, 2024, 07:37:32 AM »
Was it an olive oil and garlic and basil smell? Were you frying some meatballs on the cylinder heads whilst riding? :food:
2018 V7III Special
1978 T140V Bonneville
2004 EV Touring
Offline Tkelly
« Reply #5 on: August 05, 2024, 09:07:04 AM »
If you couldn’t smell anything,probably nothing burning.
Online cmgies
« Reply #6 on: August 05, 2024, 03:20:48 PM »
Thanks for all of your replies. I think I will take a look in the air box for any oil.
Michael Gies
'73 R75/5 (sold it)
'07 Norge (sold it)
'13 V7 Special
« Reply #7 on: August 05, 2024, 05:38:00 PM »
Make sure your clutch cable isn’t melting on a cylinder.  Pretty common on the early ‘13-‘14’s.
Offline Caffeineo
  • Guzzi B00b
« Reply #8 on: August 05, 2024, 06:09:20 PM »
Well ya know Oregon has legalized recreational marijuana. May have something to do with the other riders perception. ;)
2022 Moto Guzzi V85
2023 Husky TX300
2020 KTM 500 XCW
« Reply #9 on: August 05, 2024, 07:32:04 PM »
My 2017 V7III Special caught on fire once. While trying to start it the bike backfired blowing the intake rubbers apart.
When it finally started the mixture was so far out of whack the Catalytic converters overheated and the insulation under the heat shields caught fire.
But for a passing motorist handing me a bottle of water I might have lost the bike.I took the remaining insulation out.
Check your intake rubbers are intact.
« Reply #10 on: August 05, 2024, 08:26:06 PM »
<snip>
I'm just requoting for posterity's sake, but if the OP was accurate on the quote "smell something hot"?!?
And the OP, we're assuming is not a moron, stopped and couldn't smell, feel, find anything out of sort, why are we still taking the first moron seriously?
Op, if you honestly didn't feel anything out of the ordinary, didn't see something out of wack like tarnished mufflers, didn't smell anything weird, etc ... Forgetaboudit.
If you're not sure, take a look for some of what was mentioned, though a bike that old, if say the clutch cable was not routed properly should have failed a long time ago.
I guess if he's burning oil someone could smell it, but I'd hope a vintage guy would recognize the signs and smell and be more specific.
Offline Bulldog9
« Reply #11 on: August 07, 2024, 04:07:56 PM »
Cmon Brooklyn........... . It's Fuhgetabowdit...... .......  :cool:  Agree on the rest though. lol
MGNOC#23231
Online cmgies
« Reply #12 on: August 07, 2024, 05:10:28 PM »
I inspected the routing of the clutch cable and, sure enough, it was wedged into right side cylinder fins. When I reached in as best I could with my hand and pulled it out, the rubber piece that someone mentioned had been Guzzi's "fix" for this issue is melted and I can see some metal in the cable. I will be replacing it and hopefully routing it a bit better than it has been. I hope that this will also make the clutch "softer" to pull in.
Michael Gies
'73 R75/5 (sold it)
'07 Norge (sold it)
'13 V7 Special
« Reply #13 on: August 07, 2024, 05:34:22 PM »
So.... How come you didn't smell it?
Never mind
There's a hook assembly under the tank, run a wire tie to it to hold the replacement cable off the head.
Bob's your Uncle ...
« Reply #14 on: August 07, 2024, 06:38:44 PM »
Trying to insulate a cable from a hot cylinder with a bigger piece of thick rubber.  Brilliant.  Even the plug wires lay precariously close to the heat.
« Last Edit: August 07, 2024, 07:51:15 PM by Cam3512 »
Offline Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
« Reply #15 on: August 07, 2024, 08:03:52 PM »
Yeah, but they’re also insulated from the cylinder by a big piece of rubber. So they should be fine as well. :laugh:
Offline chuck peterson
« Reply #16 on: August 08, 2024, 05:05:38 AM »
I’m inclined to rename Moron #1 and give him a big thank you for pulling up and saying something, despite the possibility of being ridiculed…
I’ve had an experience where a rider (friend traveling behind me didn’t say a word as my oil line to a head split and sprayed 3 qts of dinosaur onto the motor
post the sacrifice to the gods of speed,!burnt main bearings and billowing clouds of blue smoke, he said…
“Yeah you’ve been blowing blue stuff since that last stop sign about 10 miles ago . . .”
Gee…..
Thanks…
It was a very long limp on the side of the road to a U-Haul dealer, as we were north of civilization in Maine. Any rpms above 3k sounded….deadly. Amazing really that it restarted and moved
My other better friend swapped bikes so I wouldn’t hear it and he kept it below 20 on the shoulder
You’re lucky!
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
Offline Huzo
« Reply #17 on: August 08, 2024, 05:24:18 AM »
I just re posted an old Paul Brooking post…
This story is reminiscent.
« Reply #18 on: August 08, 2024, 07:42:19 AM »
My biggest takeaway is a reminder not to ASSume anyone who rides a motorcycle has even the slightest bit of mechanical knowledge.
Offline BMCMOTO
« Reply #19 on: August 08, 2024, 09:04:55 AM »
Many people are not acquainted with the dry kind of sorta extra lean smell that can come from a bike with well adjusted fuel system and catalytic converters. It does have the smell of being hot etc. It is a hard thing to describe I guess. My Breva 750 has it. A buddy once asked me if it was ok. I ride with a guy that has a newer Yamaha, his doesn't have the smell I'm speaking of.
Brian
1989 MILLE GT
2006 BREVA 750
2004 BREVA 750
1975 CONVERT
Offline tazio
« Reply #20 on: August 08, 2024, 09:17:41 AM »
Most riders I've met have little clue how to properly maintain their motorcycles, but, we motorcyclists come from all walks of life, backgrounds, and passions, mechanical aptitude isn't a prerequisite for owning a bike
It CAN make it less expensive to operate and safer by far.
The OP did the right thing by not jumping to conclusions and investigating a fellow riders observations.
We're all in this together.
1967 Kawasaki 650 W2TT
1966 Triumph Bonneville
Offline Moparnut72
« Reply #21 on: August 08, 2024, 10:44:57 AM »
Back when I started riding we had to know how to fix things. Cell phones were something only Dick Tracy had, motorcycle shops weren't as common as they are today and the bikes were far less reliable. I remember the time a buddy's Triumph blew a spark plug out of the head. We were a long way from home. We fixed it on the roadside well enough to get home to do a proper repair.
kk
Mopar or Nocar
Current Bike:
2026 Triumph T120
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
