V85 Travel
Topic: V85 Travel (Read 1550 times)
snobear
Hatchling
1987 California II, 2022 V85, 2012 DR650,
V85 Travel
August 13, 2024, 04:57:50 PM »
For those with the V85 Travel plastic side cases are they strong enough to take the occasional offroad tip over or are the mounts quite light?
1987 California II
2022 V85
2010 DR 650
I do these things not to escape life but so life does not
escape me
Trialsman
Gaggle Mentor
Re: V85 Travel
Reply #1 on:
August 13, 2024, 07:20:08 PM »
I think the mounts will hold, but I am not sure on the hinges. When I went out west I put a Kevlar tie down strap around each case and also looped it through the rack, just in case it would hold some of the weight . I had no problems and don't know if I would have - just to be safe.
2010 FE570 Husaberg
2019 Alta Redshift EXR
2021 Moto Guzzi V85TT Centenario
2024 Stelvio V100
2025 Arctic Leopard Ex-800
sunGuzzi
Re: V85 Travel
Reply #2 on:
August 19, 2024, 05:03:58 AM »
I've taken my Travel with its Urbans across tough treks in outback Aus, and the plastic cases themselves held up quite well...even from a fly-off (see below) and an altercation with a Skippy roo. Pannier bounced back into closing shape no problems. The weak point was the mount onto the rails. Where the keylock slide on the pannier locks into the plastic mount appears to break rather easily when impacted pushing the pannier back...as one kangaroo proved. The other side broke too from a nap while traversing a patch of deep sand at low speed and the brain not switched on. YMMV
jackren
New Egg
Re: V85 Travel
Reply #3 on:
August 19, 2024, 06:44:20 AM »
I think they are crap, look good but damage easy and very crappy hinges.
V85 Travel
