Author Topic: 2016 v7 Stone - front indicator swap  (Read 1275 times)
Offline Auzza
« on: August 15, 2024, 08:32:19 AM »
Hi all,
Has anyone swapped the front indicator lights on a 2016 V7 stone?
I picked up some Rizoma and not sure if there is a quick connect or if i have top take the tank off.
Thanks !
Offline cowtownchemist
Re: 2016 v7 Stone - front indicator swap
« Reply #1 on: August 19, 2024, 08:15:00 AM »
I swapped mine on a 2014 V7 stone.  Should have similar electronics to yours.  You can take the tank off and there is a quick connect.  But you will also need to find the same connection type to attach to the wires of your new signals.  What I did was just cut the wires of the old ones and then solder the new wires to them with some heat shrink on top to keep the water out.
2014 V7 Stone
2000 V11 Sport
Offline Auzza
« Reply #2 on: August 19, 2024, 09:22:07 AM »
Hey thanks!
So I found the quick connect to the 2015 model from rizoma.  For some reason they didnt have 2016.
I would assume they are the same as both were not LED yet
