Author Topic: SP1000 Headlight conversion?  (Read 2928 times)
Offline CT Dharma
« on: August 31, 2024, 04:56:08 PM »
Anybody put a LED headlight lamp in a SP1000 ['80]? Have seen several discussions with links but none seem to be active anymore. Seems like an odd lamp as it doesn't have the three prongs like a normal H4 lamp. Will I need an adapter ring?
Thanks in advance
1980 SP1000 original owner
1998 V10 Centauro
1982 Honda CX500TC Turbo
2005 BMW R1100S BCR
1987 BMW K100RS
2022 BMW R1250RT
1998 Bimota DB3
1990 BMW K1
"When I'm riding my motorcycle, I'm glad to be alive. When I stop riding my motorcycle, I'm glad to be alive" - Neil Peart 1952-2020
Offline larrys
Re: SP1000 Headlight conversion?
« Reply #1 on: August 31, 2024, 05:42:01 PM »
On my '83 SP I swapped in a headlight shell from a late '70's Kawasaki KZ 1000.
Had to edit as my memory from 40 years ago wasn't clear.
I fitted a Bosch lens and reflector into the Kawasaki headlight shell. It was the same diameter as a common car headlight. It was made for a H4 halogen bulb.
Larry
« Last Edit: September 03, 2024, 01:43:40 PM by larrys »
'13 Monster 1100 EVO
'95 Cal 1100
'68 Bonneville
MGNOC 7248
« Reply #2 on: August 31, 2024, 07:20:42 PM »
Thanks in advance
It sounds like you have a bulb with P45T base instead of the more common P43T. I have some adapters that I bought here:
https://www.classiccarleds.co.uk/collections/headlight-led-bulbs/products/p45t-r2-h5-to-p43t-h4-bulb-adapter
and will send you one for free, just PM me your address.
There are LED bulbs with the P45T base, this is one that appears to have the same focal length as a Halogen bulb, which is important for proper beam spread and pattern.
https://www.amazon.com/GTMOTO-R2-P45t-LED-Bulb/dp/B0CJC6SLJ6
Offline CT Dharma
« Reply #3 on: August 31, 2024, 07:45:15 PM »
Thanks Charlie, some good information and a generous offer. Let me do some research and get back to you.
Scott
1998 V10 Centauro
2005 BMW R1100S BCR
1987 BMW K100RS
2022 BMW R1250RT
1998 Bimota DB3
1990 BMW K1
Online pehayes
« Reply #4 on: August 31, 2024, 10:52:54 PM »
I converted my SPII which I think has the same socket base issue as yours.  Read this thread:
https://wildguzzi.com/forum/index.php?topic=116230.0
I did have to abandon the quick release bail wire and just make up a safety wire substitute.
Offline CT Dharma
« Reply #5 on: September 01, 2024, 01:57:11 PM »
Charlie - Since I already have a H4 LED lamp I'll take you up on your generous offer for the adapter. I'll PM you my address.
Another reason why this forum is the BEST.
« Last Edit: September 01, 2024, 01:59:07 PM by CT Dharma »
1998 V10 Centauro
2005 BMW R1100S BCR
1987 BMW K100RS
2022 BMW R1250RT
1998 Bimota DB3
1990 BMW K1
Online cliffrod
« Reply #6 on: September 01, 2024, 10:01:03 PM »
Curious- is a 1980 SP100 headlight the same as a 1981 CX100 headlight?  I wouldn’t mind upgrading my bike while I’m at it…
Offline CT Dharma
« Reply #7 on: September 03, 2024, 09:09:55 AM »
Not sure if they're the same but this is what mine look like.
« Last Edit: September 03, 2024, 09:10:28 AM by CT Dharma »
1998 V10 Centauro
2005 BMW R1100S BCR
1987 BMW K100RS
2022 BMW R1250RT
1998 Bimota DB3
1990 BMW K1
Online cliffrod
« Reply #8 on: September 03, 2024, 10:59:00 AM »
Guess not, at least not without some convincing.  my headlight is square.
