Author Topic: Rear Hub Vent Confusion  (Read 1685 times)
Online Walter
« on: September 04, 2024, 08:15:44 PM »
I have the oil splatter on the rear wheel problem with my 2017 V9.  My understanding is that I need to remove the vent bolt and clean it, however as shown in the picture it is partially behind the hub.  Is there any way to get this thing out without removing the wheel?
Also pictured is the rear vent bolt on my 2016 V7, which has the bolt exposed and easy to access.  I don't feel the newer design on the V9 is an improvement!
1970 Ambassador
1989 LeMans
1998 California EV
2001 California Stone
2001 California EV
2002 LeMans
2006 Breva V1100
2016 V7 Stone
2017 V9 Bobber
1983 BMW R65
2015 Triumph Thunderbird Storm
1999 Harley Davidson Heritage Springer
2006 Harley Davidson Sportster 1200
Online John A
Re: Rear Hub Vent Confusion
« Reply #1 on: September 04, 2024, 08:47:31 PM »
It looks like it has a cap that could be removed and that might give enough room to take out the vent.
« Reply #2 on: September 05, 2024, 05:53:30 AM »
Isn't the cap an integral part of the vent?
« Reply #3 on: September 05, 2024, 06:22:34 AM »
It might actually be the seal is shagged.
Online Vagrant
« Reply #4 on: September 05, 2024, 06:59:34 AM »
9 times out of 10 it's too much oil. 160CC's is the max to fill a well drained unit.
2016 V7II, 2017 V7-III Blue special, 2022 V85 the fast red one! 2016 650 Versys 2023 V85 Guardian of the Oreo's
Online John A
« Reply #5 on: September 05, 2024, 08:07:36 AM »
On some of them they are just a stamped steel cup, held on with a light crimp and can be prized off with a screwdriver. To put it back on , give the crimp a little squeeze to tighten it up and push it on. The pic looks like it might be that type.
Online Walter
« Reply #6 on: September 05, 2024, 09:03:02 AM »
Thank you for all the replies!  (Except guzzisteve...).  There is a rubber cap I pulled before taking the picture.  Thanks for pointing out that it is usually an overfill situation.  Instead of focusing on the vent I'll just verify proper fill level as it was last serviced by the shop selling it.
1970 Ambassador
1989 LeMans
1998 California EV
2001 California EV
2002 LeMans
2006 Breva V1100
2016 V7 Stone
2017 V9 Bobber
1983 BMW R65
« Reply #7 on: September 05, 2024, 10:02:17 AM »
OK, fixed it.
« Reply #8 on: September 05, 2024, 11:08:05 AM »
Double check the manual for the correct amount of rear end oil. On the V9 it might be closer to 200cc IIRR.
To get the vent out without the rear wheel off. Another thread mentioned turning the OD of a socket down, a normal socket will not fit between the vent and the housing. When I removed one, the wheel was off and used an open end wrench.
I'm sure you know, but to add oil, you put it in through the level hole.
Good luck,
Online Walter
« Reply #9 on: September 05, 2024, 11:23:09 AM »
Thanks Tom, that's very helpful.  It looks like there is not enough room even with grinding a socket but I'll give it a try.  I'm ok with pulling the wheel but always looking for workarounds if they're out there!
1970 Ambassador
1989 LeMans
1998 California EV
2001 California EV
2002 LeMans
2006 Breva V1100
2016 V7 Stone
2017 V9 Bobber
1983 BMW R65
Online Vagrant
« Reply #10 on: September 06, 2024, 08:59:12 AM »
The books were wrong on the v85. They finally revised them to 160CC. I was under the impression the v9 has the same box.
« Reply #11 on: September 06, 2024, 03:11:15 PM »
Per the V9 Roamer and Bobber manual on Cadre Cycle. Is there a revision?
210CC for the rear drive.
85W-140 conventional gear oil GL5
Offline mechanicsavant
« Reply #12 on: September 08, 2024, 05:04:25 PM »
It looks similar to my 21 V7/850 . Even with the final drive sitting on workbench I couldn’t get a tool in there . So to verify vent operation I set the final drive upside down (after draining) removed the drain plug & poured 2oz. Of alcohol in . It went through & came out the vent ! So , the vent is working . A new pinion seal is going in soon !
