Did you actually torque them to spec? The nuts on my V7 II would often come loose—same with my valve cover screws— unless I actually torqued to spec.
I think if you search a bit more you'll probably find that high temp loctite is not exhaust port high . They're pretty easy to check every now and then , aren't they ? Peter
It seems like the nuts had loosed a bit just in the couple of weeks between putting the headers on and taking them off. Am I OK to use some blue loctite here or would that not be advisable with the heat of the engine?
Wave washers can't handle the heat. The lock washer you want is Schnoor. They can handle the temps.
…Another interesting solution to exhaust components 'welding' together is silicone sealer. They may be slightly more difficult to separate, but they certainly won't be rusted together.
The go-to exhaust sealant we used for daily rider shovelheads (including mine) was the hi-temp copper silicone gasket sealer. Original heads only have a single bolt (or stud to avoid wrecking aluminum threads as easily) to attach exhaust to the aluminum head. That arrangement leaves a lot to be desired. The copper silicone helps a lot, both to seal the connection and keep the single bolt/stud & nut in place, even though it needs to be applied with discretion to avoid the bubblegum look. Using a dab on threads, HD or Guzzi, to keep nut in place can be almost invisible if done right.
