Author Topic: Preferred CARC front brake pads  (Read 4052 times)
Offline brider
« on: October 16, 2024, 07:51:11 AM »
Last thing I need to buy to get my Norge back on the road are new front pads. I swapped in a set of Grimeca rotors taken off a 2014 model (mine's a 2007).
Mainly looking for what NOT to install, if there are certain compounds to avoid (for whatever reason). Calipers are original 2007 Brembo.
'85 Cal II Auto
'71 Ambo project
'02 GasGas EC300
'07 Norge
'05 KTM 950 Adventure
Wish'd I'd never sold:
'72 Red Eldo
'74 White Eldo LAPD
'77 Convert with DB bags
'06 Gas Gas EC300
'86 LM IV
Re: Preferred CARC front brake pads
« Reply #1 on: October 16, 2024, 06:09:42 PM »
9hrs and no answer, time to do a search.
Offline azccj
« Reply #2 on: October 16, 2024, 09:38:03 PM »
Back when I had my 2007 Norge, the OEM front brake pads quickly caused the front brakes to pulsate within 3,000 miles from new. My dealer got me new front rotors under warranty because I thought the rotors were warped. When I installed the new rotors I installed EBC Double-H Sintered Metal Brake Pads, and never had the pulsating return. That was until I reinstalled the OEM pads years later, at which point the pulsating returned. Most likely the OEM pads were transferring some pad material onto the rotors causing the pulsating. I long ago sold the Norge but I still have those original Norge rotors somewhere, which I'm fairly sure are fine. So my advice is to go with EBC Double-H Sintered Metal Brake Pads.
Oddly enough my V100 Mandello recently started having the same pulsating front brake problem after just 4,000 miles. I removed the OEM pads, and used a Scotch-brite pad to clean the rotors. I then installed EBC Double-H Sintered Metal Brake Pads. The pulsating is gone and the brakes are a bit more powerful with the HH pads.
« Last Edit: October 16, 2024, 09:41:30 PM by azccj »
2023 V100 Mandello S
2007 Norge
2003 V11 Le Mans
2000 Jackel
99 EV
Offline OtisV11
« Reply #3 on: October 17, 2024, 12:23:23 AM »
Sintered pads will pull you up a lot sooner if you doing a lot off heavy braking but will wear your rotors out sooner.Ive personaly have gone to organic pads on my v11 for normal riding cause they not so hard on the rotors but need replaceing more often than sintered one.I know which job i would rather do and its not the rotors. :boozing:
Offline Ratso88
« Reply #4 on: October 17, 2024, 09:09:21 AM »
I've been running EBC HH Pads on my '13 GRiSO, probably 30K miles. I think I replaced them at the first service, I'm at 36K now.
No issues stopping rain or shine. I haven't ridden with snow flying yet.
Stock rotors are holding up but I will probably replace then over the winter along with a general refresh.
Offline kidsmoke
« Reply #5 on: October 17, 2024, 01:58:29 PM »
...yet
Funny, I've been researching brakes for Perla the last week or two as well.
'79 G5      (Gina)
'93 1000S (Monica)
'00 Jackal  (Claudia)
'09 GRiSO  (Perla)
Online Bulldog9
« Reply #6 on: October 17, 2024, 02:13:46 PM »
This is what I use on all my bikes. Great pads. Long life quiet and great performance
MGNOC#23231
« Reply #7 on: October 18, 2024, 09:20:01 AM »
EBC HH
Offline brider
« Reply #8 on: October 18, 2024, 09:40:13 AM »
OK then, EBC HH pads sound like a proven good choice, thanks!
'85 Cal II Auto
'71 Ambo project
'02 GasGas EC300
'07 Norge
'72 Red Eldo
'74 White Eldo LAPD
'06 Gas Gas EC300
'86 LM IV
Online Dr. Enzo Toma
« Reply #9 on: October 18, 2024, 02:46:41 PM »
Almost every modern motorcycle I've owned has come with factory brake pads that end up squealing. Cleaning the surfaces and scuffing the pads again only temporarily alleviates the issue, so now I just replace the pads with EBC HH sintered pads and the squeal doesn't return. Happened on my Moto Guzzi V7 850. I'd be curious if anyone has numbers on the extra wear to the rotors. I haven't noticed it yet, so I imagine it doesn't cut down on their life too dramatically.
2027 Moto Guzzi V7 Sport
MGNOC Member
« Reply #10 on: October 18, 2024, 08:07:23 PM »
You can dampen the squeal somewhat by applying some anti-seize to the back of the pads. Cheap Guzzi solution.
« Reply #11 on: October 18, 2024, 08:50:33 PM »
Tried it, that solves for other brake squeals, same with greasing the pin, but it doesn't solve for when the squeal is made by the pad and rotor making intentional contact as the brake is applied.
MGNOC Member
Offline 73 sport
« Reply #12 on: October 18, 2024, 09:20:01 PM »
Look up "Disc Brake Quiet" on Google, there are several brands. I've been using it for forty years, it works.
« Reply #13 on: October 18, 2024, 11:02:59 PM »
Unfortunately that approach doesn't always work. I haven't had the squeal return after replacing oem organic pads with aftermarket sintered ones though.
« Last Edit: October 18, 2024, 11:06:04 PM by Dr. Enzo Toma »
MGNOC Member
« Reply #14 on: October 21, 2024, 08:02:57 PM »
Another vote for EBC HH
I always make sure to service the rear caliper float mechanism, knock it loose, lube the pins...  every time I'm touching the brakes front or rear. seems like it gets crusty and sticky fairly readily.
