Author Topic: Tachometer issue  (Read 1132 times)
Online Guzzidad
Tachometer issue
« on: November 03, 2024, 05:39:44 PM »
 2020 V7III Racer. The tach is obviously not reading correctly. It shows 0 rpm at idle and only 3000 rpm at an indicated 80mph. I'm assuming the tach is electronic and gets its values from the ecu.
Re: Tachometer issue
« Reply #1 on: November 03, 2024, 06:18:23 PM »
You are correct, clean plug to dash, look in service manual.
