Author Topic: Valve clearances/ tdc  (Read 11819 times)
Offline NHMike
Re: Valve clearances/ tdc
« Reply #30 on: November 07, 2024, 08:54:07 AM »
Make sure that you're on the compression stroke and not the exhaust stroke.
Rotate the rear wheel, watch the straw/stick/spoke you stuck in the spark plug
hole to make sure the piston is at the top of it's stroke on the side you want to adjust.
Then, grab the rockers and make sure that you can feel just a bit of play. If there is
that tiny bit of play, you're on the compression stroke. If not, you're on the exhaust
stroke and you need to rotate the engine one more revolution. You'll get it.
Repeat for the other side, moving the straw/stick/spoke to that cylinder to check that it's
at TDC on the compression stroke.
What if there is only a little play in one of the rockers?
                                                       -Stretch
2023 V7850 Stone
« Reply #31 on: November 07, 2024, 09:05:41 AM »
It’s rare to find one that the timing marks are accurate enough to use for super tuning when they are compared to true TDC. You’ll see a timing marker bolted to the inside of the bell housing that is visible through the timing hole on older ones that run points on tweaked Guzzi’s.
« Reply #32 on: November 07, 2024, 09:07:41 AM »
                                                       -Stretch
Then:
* You're not at TDC
* There's not enough play on that adjuster
The first is more likely but the second is possible.
« Last Edit: November 07, 2024, 09:07:55 AM by Kev m »
Online PeteS
« Reply #33 on: November 07, 2024, 09:18:42 AM »
This is true. Anyone who has degreed a cam or had any reason to mount a degree wheel to find true TDC will make new marks if the factory ones are off. That is if they are smart and don’t want to go through that process again.
Offline NHMike
« Reply #34 on: November 07, 2024, 01:36:33 PM »
Then:
* You're not at TDC
I finally got her all sorted! Once I figured out the compression stroke everything fell in place sorta speak.😁 bike is running perfect now! Thanks for all your input!
2023 V7850 Stone
« Reply #35 on: November 07, 2024, 02:32:59 PM »
Congrats! :thumb:
Now you know, it will be easy next time.
Offline Stretch
« Reply #36 on: November 07, 2024, 03:44:03 PM »
There ya go! Gettin' the piston at TDC is a big part of the battle.
Now you COMPLETELY understand because you've done it!  :grin:
                                            -Stretch
1967? Change Jiang M1M
1978 Yamaha SR500
1971 BMW R75/5
1987 BMW K75S
2011 Kawasaki KLR650
2015 Triumph Trophy
Offline Huzo
« Reply #37 on: November 07, 2024, 04:06:54 PM »
Guys..
I rang Mike while I was doing my shopping for vegetables and the explanation took 10 minutes, the guy would have been saved a LOT of heartache if someone had just picked up the damn ‘phone… :rolleyes:
« Reply #38 on: November 07, 2024, 04:33:12 PM »
Not everyone wants to post their phone number. PM it more likely.
Call international.... Not sure what that would have cost you.
VERY GOOD that you did it :thumb: :bow: :thumb:
Offline Huzo
« Reply #39 on: November 07, 2024, 04:44:08 PM »
My plan gives me 5 hrs “free” international hours per month. I rarely use more than half, use it or lose it.
I figure I’d save that multiple times over if I stayed in New Hampshire at Mike’s place for one night.
Offline NHMike
« Reply #40 on: November 07, 2024, 04:56:46 PM »
Yup!!
                                            -Stretch
2023 V7850 Stone
Online Pescatore
« Reply #41 on: November 09, 2024, 12:13:47 PM »
NHMike, feel free to ping me if you need help. I'm not far from you and frequently in NH.
Huzo, you got a place near Boston as well.
2008 Norge red
1991 V65GT
1980 CM400T
MGNOC Member
Offline Huzo
« Reply #42 on: November 09, 2024, 02:00:58 PM »
:bow: :thumb: to you Pescatore and thank you.
Offline NHMike
« Reply #43 on: November 10, 2024, 06:40:49 AM »
Thank you sir!!
2023 V7850 Stone
