Author Topic: Lemans Charge light  (Read 1612 times)
Offline Cal3Me
Lemans Charge light
« on: November 06, 2024, 02:49:49 PM »
the new to me Lemans IV has a charging light that doesn't come on with key on. Bulb is good. Test light when grounded and touching alternator blue wire bulb will light up bulb with key on and bike not running. Bulb does not go out with bike running. Voltmeter test at battery shows bike is charging when running.
I miss having a flickering charge light that guzzi's are supposed to have.  :thumb: is there a fix ........
TMS
Offline Frenchfrog
Re: Lemans Charge light
« Reply #1 on: November 06, 2024, 04:27:17 PM »
has to be in the wiring or bulb holder then...
« Reply #2 on: November 06, 2024, 05:30:33 PM »
Could be how wires are routed in the dash line up, most likely touching the socket. I'd try another bulb too, never know. Bad spade connector possible too.
« Last Edit: November 06, 2024, 05:32:23 PM by guzzisteve »
Offline Old Jock
« Reply #3 on: November 07, 2024, 03:36:24 AM »
As the 2 above solutions or possibly brushes/slip ring dirty or hung up on the ALternator
Offline chuck peterson
« Reply #4 on: November 07, 2024, 04:27:02 AM »
Brushes worn down?
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
Offline jacksonracingcomau
« Reply #5 on: November 07, 2024, 06:38:08 AM »
Properly odd, classic rotor gone open circuit symptoms, but then it wouldn’t charge
Multimeter will tell all, perhaps a wiring thing ? What max volts does it give?
Offline Moparnut72
« Reply #6 on: November 07, 2024, 07:06:54 AM »
Brushes worn down?
My R75/5 did this. Exact same symptoms, not necessarily your problem but easy to check. Same alternator I believe.
kk
Mopar or Nocar
2023 V100 Navale
2019 V7lll Special
MGNOC #24053
Offline Cal3Me
« Reply #7 on: November 07, 2024, 07:33:19 PM »
new bulb tried with no change. Bulb & socket tested good all by it's self not connected to the wiring harness on the bike. Looked at the brushes and they seem fine with good tension from the springs. Bike started fine the day before.
Checked battery voltage next with voltmeter had 12.8v, next test was to start bike and read voltage at battery again for output. Bike won't start just kept cranking but no pop, fart or bang...no power to the coils. I thought maybe I hit the kill switch by mistake so I flipped the switch and a BIG BANG happened !  Could that bang damage the dyna black box?
Still No power to the coils now so no sparky. All this just because I wanted to figure out why the battery charge light didn't work.... :thewife:
No smoke was released during this whole sequence of events
TMS
Offline Cal3Me
« Reply #8 on: November 08, 2024, 03:59:03 PM »
power back on , seems eye have a fiddley kill switch , but still no charge lite... Oh well, bike is charging up to 13.8 volts at the battery while running.
Carry on ......  :boozing:
TMS
Offline guzziart
« Reply #9 on: November 09, 2024, 08:43:44 AM »
Great!
Yeah, years ago I took both hbar switches apart, cleaned the contacts, etc.   I seem to recall something up there using the hbar as a return ground path so that business has to be clean too.  I also put the kill sw circuit on a relay to keep that current out of the switch. fwiw.
Art
'72 CL350, '72 Eldo '87 LMIVSE, '91 CT70, '08 Wing, '23 v85 Travel
