Author Topic: Le Mans CX100 Vacuum / Barb Adapter Fittings  (Read 4706 times)
Offline lomax
« on: November 24, 2024, 05:27:54 PM »
I need help from the amazing and knowledgeable Guru's that reside on this forum.  :bow:
I have a 1980 moto Guzzi Le Mans CX100 and am trying to do a carb setup on it. It runs great but I want perfect. I do have a harmonizer to do the balancing but cannot seem to find Vacuum / Barb Adapter Fittings that will fit the intake. I have tried Motion Pro 5 and 6mm fittings and they are too small, I tried 8mm fittings and they are a bit too big. For the life of me I cannot find 7mm fittings. Or could they be 1/4 " SAE (which I also cannot find) . I highly doubt that as it is Italian. They are NOT pipe thread. Can anyone point me in the right direction to find adapters or give me any advice on how to proceed.
This is what I am lookin for
And this is where they need to fit. The small silver screw in the black rubber boot.
« Last Edit: November 24, 2024, 05:30:59 PM by lomax »
64 R50/2, 01 DRZ400E, 23 Triumph Speed Twin, 81 Moto Guzzi CX100, 21 Africa Twin, 22 Janus Halcyon, 81 CBX, 80 GB500, 73 RD350, 1944 Nimbus type C, 14 Moto Guzzi V7 Racer, 73 Norton Commando.
Online pehayes
Re: Le Mans CX100 Vacuum / Barb Adapter Fittings
« Reply #1 on: November 24, 2024, 06:06:11 PM »
Several indicators in that carb pic tell that things are not stock original.  Pull the allen head screw and verify if it is SAE or metric and what pitch.  Find some hobbyist with a lathe and he could reproduce those fittings in a flash.  I've made my own several times.  Otherwise, pull the manifolds and re-drill and re-tap to whatever dimension you prefer.  If it were stock I'd send you to Motion Pro as their fittings are relatively simple and cheap.
Fremont A
« Reply #2 on: November 24, 2024, 07:35:34 PM »
Since those Delrin manifolds are made in Europe, the thread is going to be metric. I have a pair here and can measure the thread size tomorrow when I'm back in the shop.
« Reply #3 on: November 24, 2024, 08:05:20 PM »
Tips for a mig welder can be found in the correct size and thread if you want high quality hose nipples . 6x1 mm by memory.
« Reply #4 on: November 25, 2024, 02:32:22 PM »
I just checked - the vacuum port thread size on those Delrin manifolds is M6-1.0. There is a Heli-Coil type insert in the plastic that could possibly come out, so make sure that's still in place.
Offline guzziart
« Reply #5 on: November 25, 2024, 03:59:44 PM »
Yep, the helicoil does come out.....usually with the screw in it :laugh:.
FWIW, I got sick of fiddling with them so the last time they came out, I cut a small length of brake pipe, installed a couple threads (same O.D. as the helicoil O.D.), added a dab of JB Weld and screwed them into the manifolds, capped them off with common vacuum port caps, aint been a problem since....that was 11 years ago.
Art
« Last Edit: November 25, 2024, 04:01:35 PM by guzziart »
Offline lomax
« Reply #6 on: November 29, 2024, 03:34:32 PM »
Brilliant Idea, I will give that a try . Thanks
« Last Edit: November 29, 2024, 03:35:28 PM by lomax »
Offline lomax
« Reply #7 on: November 29, 2024, 03:38:23 PM »
That would be greatly appreciated. I am thinking tapping and JB weld might be the ticket if the welding tips don't work.   Thanks.
« Reply #8 on: November 29, 2024, 04:26:45 PM »
I believe the usual thread in Guzzi's is 6mm
I have used a pair of 6mm grease zests with the ball removed.
plastic tubing will get soft and fall off, you really need a short length of rubber hose in the adapter, rubber can take the heat.
« Reply #9 on: November 29, 2024, 04:38:52 PM »
I already responded a few days ago.
Offline John Croucher
« Reply #10 on: November 30, 2024, 10:08:55 AM »
I use brake bleeder nipples.  Cut the blanked taper end off or drill a hole through.  Works great.
Offline lomax
« Reply #11 on: November 30, 2024, 07:34:31 PM »
Mystery solved. While at the shop today for other issues  :angel: We found that YES they are M6-1.0 nipples just like Antietam Classic Cycle said. The ones I got from Motion pro were evidently marked wrong and thus did not fit.
I can only hope this helps some one else out that may have the same question.
Thank you all for the great advice.
Marc
« Last Edit: November 30, 2024, 07:35:49 PM by lomax »
