Author Topic: Voltage surges  (Read 4204 times)
Offline tris
Voltage surges
« on: January 27, 2025, 06:35:59 AM »
Afternoon All
Some of you may know that I've left the MG fold (F800GT BMW) but I have a question that someone here may be able to answer.
My new bike has a Canbus system that controls everything,  including the factory fitted DIN connector which has a 5A limit.
I have a small tyre compressor that I'd like to carry, and when bench tested happily runs at 3.5A
However, at startup it surges to 10.5A which will cause a trip.
How can I reduce the start-up surge to something more Canbus friendly?
Cheers
Tris
1993 TW125 "POS" - Resting
Offline guzziart
Re: Voltage surges
« Reply #1 on: January 27, 2025, 09:29:20 AM »
SAE connector directly off the battery (w/15a fuse) and pump, plug-in when needed.
Yeah, I can't think of any way to lessen inrush current to your device upon start up.
Art
« Last Edit: January 27, 2025, 09:36:21 AM by guzziart »
Online Stretch
Re: Voltage surges
« Reply #2 on: January 27, 2025, 09:45:24 AM »
What Art said.....
1967? Change Jiang M1M
1978 Yamaha SR500
1971 BMW R75/5
1987 BMW K75S
2011 Kawasaki KLR650
2015 Triumph Trophy
Offline tris
Re: Voltage surges
« Reply #3 on: January 27, 2025, 11:31:35 PM »
So, aI've found a solution
I need a Negative Temperature Coefficient (NTC) Thermistor
When cold it's resistance is high reducing the current flow but as the compressor runs over a short time the Thermistor warms up and the resistance drops
They're designed to manage an excess inrush current
See 3/4 way through this
https://www.electronics-tutorials.ws/io/thermistors.html
As a Mechanical Engineer I just need to work out which one I need!!!
« Last Edit: January 27, 2025, 11:43:50 PM by tris »
Re: Voltage surges
« Reply #4 on: January 28, 2025, 08:04:28 AM »
Which means the compressor motor may be stalled by the low startup voltage, and never start spinning. Maybe.
Which means that if it does operate, the thermistor must, by design, remain VERY hot to keep the thermistor voltage drop low. So there will be a significant voltage drop to the compressor when operating, just to keep the thermistor smoking hot. Plus you need a box for it that can handle all of that heat.
Have you checked the current draw of the compressor under full load (an inflated tire)?
It is so easy to put a SAE connector on the battery, to charge the battery, or run a compressor.
Re: Voltage surges
« Reply #5 on: January 28, 2025, 11:57:02 AM »
Exactly.  Don't over complicate it.
Online ridingron
Re: Voltage surges
« Reply #6 on: January 28, 2025, 12:50:49 PM »
Art
Quick, cheap and easy. A very Guzzi solution.  :thumb:
Offline moto
  • Fear the deer!
Re: Voltage surges
« Reply #7 on: January 28, 2025, 04:53:17 PM »
Have you checked cthe current draw of the compressor under full load (an inflated tire)?
I don't think CANbus was meant to charge batteries or run compressors. If you decide to go the way that everybody's recommending, I have a tip or two. Get a 3 foot 14 gauge connector. I played with voltage drop software on the internet and decided that would be enough for my compressor. Also, watch out for the polarity of the cable you buy. Many of them are intended for solar panels and have the polarity reversed. Sorry if this is obvious to you already.
850 T-3
Griso 1100 corretto
Re: Voltage surges
« Reply #8 on: January 28, 2025, 10:18:54 PM »
As others have pointed out Canbus is not intended to power this type of a load, if you are not careful it will be destroyed/
A DC motor will always draw a high current at startup when full Voltage is applied then as it gets up to speed the motor generates a Voltage in reverse (Back EMF) so the current drops back.
Offline tris
Re: Voltage surges
« Reply #9 on: January 28, 2025, 11:52:56 PM »
Thanks everyone,  it seems that a change of direction is needed!!!
I'll sort something out wired directly to the battery.
As an aside what is this DIN socket supposed to be for?
« Last Edit: January 29, 2025, 10:35:39 AM by nmroadrunner »
Offline moto
  • Fear the deer!
Re: Voltage surges
« Reply #11 on: January 29, 2025, 12:43:30 PM »
That socket might be for electrically heated clothing.
But, backing away from my previous position, it might also be for tire pumps. The canbus can certainly switch on a high amperage circuit when it wants to, and then it is probably set up to monitor the voltage or current to make sure things are OK. It could well allow for a startup surge of voltage or current, depending on how it's programmed. The 5 amp rating would be for a continuous load.
I think the best bet is to ask somebody who knows about your BMW. Maybe the dealer knows whether you can put your tire inflator on there, or maybe there is a knowledgeable online forum of BMW owners that would have that particular answer.
850 T-3
Griso 1100 corretto
Offline John Croucher
Re: Voltage surges
« Reply #12 on: January 30, 2025, 07:22:43 AM »
Buy a co2 tire inflation kit. No electric problems.
Offline tazio
Re: Voltage surges
« Reply #13 on: January 30, 2025, 09:33:32 AM »
Yes, they saved my bacon in the middle of W.Virginia trip, a long way from home :thumb:
And, if your bike doesn't have one, a cheap TPMS can give you a heads up before you hit the next tight curve.
Ask me how I know..
« Last Edit: January 30, 2025, 09:40:34 AM by tazio »
1967 Kawasaki 650 W2TT
1966 Triumph Bonneville
Re: Voltage surges
« Reply #14 on: January 30, 2025, 12:09:11 PM »
Re: Voltage surges
« Reply #15 on: January 30, 2025, 12:12:16 PM »
Got it in a small case with everything else that's needed.  Goes with me whatever I'm driving or riding.
Re: Voltage surges
« Reply #16 on: May 10, 2025, 10:36:43 PM »
I have a small portable compressor, I threw away the plastic case it came in, shortened the hose and just touch the two wires direct onto the battery terminals, it doesn't care which way it runs.
