For inserts like Tubliss .... be aware that they're meant for dirt bikes and not the higher pressure that you want for street riding.
It is not the pressure that is the issue - the Tubeliss itself is inflated to about 100 PSI - but the heat that comes with high speed riding over distance can result in the Tubeliss failing. Mousse does not use any tire pressure but are very affected by temperature and will literally melt away.
I believe that is a common confusion, since they write "use 0-10 PSI" on their website. But that is in order to gain maximum traction in deep sand and mud, where low pressure is a benefit. With TUbliss, you do not have to worry about punctures from a pinched tube regardless of tire pressure. I cannot see any issues with running higher tire pressures with TUbliss, nor do they state any such thing that I can find.
One thing that begins to seem particularly disturbing about my idea is the inability to tell whether or not the inner tube has been compromised if the tire is still firmly inflated. Kind of the Schroedinger's inner tube thing, if you know what I mean.
