Author Topic: 1200 8V Sidecar Outfit.  (Read 39354 times)
Offline John Warner
  • Growing old is mandatory, growing up is not . . .
    • Stelvio/V85 Owners Group FB
« on: March 03, 2025, 03:45:19 AM »
Hi all.
OK, don't get the Popcorn out just yet, this is just a 'teaser' for my first Sidecar Build Project.
Hoping to start later this year.
Actually, it'll be my second, if you count the Minimoto thing I built back in the late 90s . . .
I'll be using the Drivetrain from the 2008 Stelvio I picked up a few years back.
This is the basic idea I'm aiming for, as far as the general layout and riding position is concerned, but far less 'radical' styling-wise.
I've always wanted a Road-Legal F1 Race Outfit, it's been done a few times, but this should be just a tad more practical.
I've decided on the Front-End design.
I do like the one above, but I much prefer the Dual Arm types, with all the 'workings' within the Wheel, so it will be similar to the Krauser Domani.
Nice simple Box-Section Structures, skinned with thin Sheet Steel . . .
Definitely won't be painting it Pink though!
Will be using Car Components as much as possible, got the Stub Axles today for the front and Sidecar Wheels, will get the Hub Bearing Assemblies once I've decided what Wheels to use.
Thoughts on the Rear-End Arrangement . . .
I'm determined to have the Rear Wheel 'right-way-round' for a L/H Chair, so I'll be making a Swing-Arm for it.
Something along these lines . . .
I would have done that anyway, as Guzzi recommend not fitting a Sidecar to any of their CARC Models, due to the extra strain it puts on the Arm.
Mind you, there are plenty of CARC Outfits out there, on and off-road versions, and I've yet to see/hear of any failures.
Anyway, I have two basic choices as I see it, both obviously converting to Chain-Drive on the left of the Arm.
I'm thinking I can mount the CARC (Final-Drive) Unit directly to the rear of the Gearbox, linking the Gearbox Output and FD Input Splined Shafts with a Splined Sleeve (ends of the Shafts touching).
So the two basic options with the above in mind;
1. Have the Engine/Gearbox in-line with the Wheels, and have a Cross-Shaft bolted to the CARC Hub (where the Bike Wheel normally bolts on), which takes the drive over to the left, Sprocket mounted on that end.
Pros;
Keeps it looking more Bike-and-Sidecar.
Feels 'better', more natural, having the Engine directly in front of you?
Cons;
More work, parts to make, and more complex Structure having the Cross-Shaft.
More Structure to build for mounting the Front Suspension.
Larger, more complex Arms at the front?
2. Shift the Engine/Gearbox over to the left, Sprocket bolted directly to the CARC Hub, in-line with the Rear Sprocket.
Pros;
The whole Outfit would be more 'balanced', better handling, particularly in left-handers.
Less work, less parts to make, no Cross-Shaft needed.
Front Suspension Arms would be simpler to mount, as they could be inline with the Engine, so less and/or simpler Structure to build.
Arms could be more 'compact', more 'direct' connection from Pivots to Wheel Hub.
Swing-Arm would also be more in-line with the Gearbox, easier mounting, less Structure to build.
Cons;
Takes it away from the 'normal' Bike-and-Sidecar layout.
Might feel 'odd' for the Driver.
Encroaches on Chair space.
Thoughts?
« Last Edit: March 03, 2025, 04:24:21 AM by John Warner »
Doc out . . .
Stelvio Owners Group on FB ~ https://www.facebook.com/groups/888995181188209/?fref=nf
Offline John Warner
« Reply #1 on: March 03, 2025, 04:27:55 AM »
I've been scouring the Internet looking for Splined Couplers, to join the Gearbox Shaft to the CARC Unit.
I do have the Driveshaft from the Bike, but I didn't want to sacrifice the two End Yokes.
Was thinking I'd need to cut and machine them down, and weld them together, then all of a sudden it hit me . . .
I can just take the End Yokes, and join them with one of the Spiders, no butchery required.
Found this while researching Chain Drive conversions, glad to know it's been done, and works, although there's no reason it wouldn't of course.
Doc out . . .
Online AJ Huff
Re: 1200 8V Sidecar Outfit.
« Reply #2 on: March 03, 2025, 08:21:54 AM »
Way over my head but sounds like an amazing build!!!
-AJ
'71 Ambassador
'01 California Special
'05 Road King
MGNOC# L-753
Offline John Warner
« Reply #3 on: March 03, 2025, 09:53:27 AM »
Still mostly in my Head at the moment AJ, but it should be fairly straightforward fabrication for the most part.
I have two Lathes and a Milling Machine for the more 'technical' stuff, TIG & MIG Welders, Plasma Cutter, Band Saw, Pillar Drill, and all the other Tooling I'll need (hopefully).
Doc out . . .
Offline John Warner
« Reply #4 on: March 06, 2025, 04:07:42 PM »
Just ordered Wheels for the Project.
I've been scouring the internet looking for some decent Wheels, at a reasonable price.
Found these today which will be perfect, they're around half the price of all the others I've seen.
Set of four (not sold singly) £275 Delivered, last set in a sale.
The comparable sets I've been looking at have been around £550-650
They're exactly the design I've been looking for, no compromise required on my part.
15", 5x112 PCD, 6.5" Width.
« Last Edit: March 06, 2025, 04:08:26 PM by John Warner »
Doc out . . .
Offline Turin
« Reply #5 on: March 06, 2025, 07:43:03 PM »
I'm partial to these.
1985 Sidlow Guzzi
Offline John Warner
« Reply #6 on: March 07, 2025, 04:03:21 AM »
Yeah, beautiful.
That's the kind of thing I've always fancied for the Road, I may still do it sometime, but this one should be just a tad more practical (relatively speaking!!), and a bit more 'inviting' for sane Passengers.
It's been done several times . . .
Doc out . . .
