Author Topic: Tail light Wiring California III  (Read 1947 times)
Offline Turin
« on: April 16, 2025, 10:33:17 PM »
I'm probably overthinking this.  The harness from the Cal III has 4 wires. 2 black (ground) 1 yellow ( running light), and one red/blue ( brake light).
The taillight I want to use has two wires. I can run all the grounds together... can I run the running and brake lights to the one power wire on the new lamp?
Thanks!
1985 Sidlow Guzzi
Re: Tail light Wiring California III
« Reply #1 on: April 16, 2025, 11:16:59 PM »
I usually just swap the socket and pigtail to a dual filament. Some lights are easy, some take a little modification. If you can find the right socket, there are many styles , it helps. I don’t know if you can hook the two together , I never tried that. https://www.autozone.com/power-tools/electrical-socket/p/dorman-conduct-tite-tail-light-socket/600544_0_0  or similar
« Last Edit: April 16, 2025, 11:21:50 PM by John A »
Offline Turin
« Reply #2 on: April 17, 2025, 01:00:32 AM »
I opened the light and found two bulbs! the black wire goes to the bottom bulb, and the green goes to top. I suspect I'll need to run a ground to the bracket.
I also could be very wrong. Spent a few hours scratching my head.
1985 Sidlow Guzzi
« Reply #3 on: April 17, 2025, 09:52:59 AM »
That sounds right!
Offline Turin
« Reply #4 on: April 18, 2025, 06:06:29 PM »
Go figure that on a Ford Model A tail light, the running light wire is black and the brake light wire is green. I'm so used to black beaing a ground that I didn't think. I ran the guzzi ground wires to the stainless bracket.
Thanks John, sometimes I need a sounding board to figure sh!t.
1985 Sidlow Guzzi
