Author Topic: Taller Norge shock?  (Read 1029 times)
Offline SemperVee
  • USMC Retired
Taller Norge shock?
« on: April 21, 2025, 03:56:45 PM »
 I have located a used  13" shock but it is 1/2 inch longer than stock Sach unit.   Has anyone had experience with installing a taller shock on their Norge?
 I know it will cause the saddle to be a bit taller but I am wondering if it materially changed your handling to feel unstable?
53 years of Street Riding - All Brands
2007 MG Norge - VroomHilda
2003 Cali Hydro EV
2012 Victory CCT
2007 MG RED Norge
14 Harleys 2 VStrom 1000's
Offline Alfetta
Re: Taller Norge shock?
« Reply #1 on: April 21, 2025, 04:04:35 PM »
IMHO,  any raise in the needs needs to be matched at the front otherwise you are changing the rake and trail of the bike.  Raising the rear without raising the front will typically make the steering "quicker" but slower to return to a neutral line. head shake can occur if rake and trail change is sizable.
side note, if a longer shock is added and then sag is set so the bike returns to original rake/trail values, the result is typically that you are back to the original shock travel.
Online Bigtime
« Reply #2 on: April 21, 2025, 04:29:23 PM »
  Reach out to Jim Hamlin at Hamlin Cycles. He is the absolute expert on suspension for the carc Guzzis.
Offline SemperVee
  • USMC Retired
« Reply #3 on: April 21, 2025, 06:00:00 PM »
I also think that also is partially true using sag setting technically but was hoping to hear from anyone who has actually done it?
2003 Cali Hydro EV
2012 Victory CCT
2007 MG RED Norge
